586,082 active members*
3,836 visitors online*
Page 1 of 3 123
Results 1 to 20 of 49
    Aug 2011
    53
    Where are you located?
    This may not be proper forum protocol, if so will the moderator please remove it. It would be interesting to know where the Momus machines and those in various stages of completion are located. There might be one right around the corner and not know it. I am in central Texas. If you don't mind letting us know where you are, please post a response.
    I don't make mistakes ... I make 'unintended engineering design changes'.
    Oct 2010
    30
    I'm in the Minnesota.
    My woodwork is basically done (no doors or cover yet.) It turned out better then I expected.
    (My wife bought me a small table saw a couple years ago and I'd even turned it on twice. Once to see the blade spin around and once to cut a piece of wood )
    Metal work is at about 70%. Just got my ground stock for the rails yesterday. The parts are not as good looking as some of the examples I've seen here but I'm sure they will work fine.
    A couple of the parts I won't do until I get the motors. I'll probably pick up the motors and electronics with my tax refund
    Nov 2011
    I live in Orlando any machinist located here? I am a wanabe but been kind of discouraged after asking forum's what the thought. Burned out and want a new challege been in Countruction 32 years.
    Mar 2011
    144
    Sarasota, FL ...... I have completed mine about year ago.. and just got sherline mill plus going to build new one using THK rails and THK actuator for z axis.
    Aug 2011
    17
    Minnesota here. About completed with the metal and starting on the wood.
    May 2010
    118
    Colorado Springs, CO. Up and running like a champ.
    Randy
    May 2011
    24
    Oregon. I did the metal first, which is all done. I'm just starting on the wood base. I added 12" to the X axis, and 1" height of the X rails to get a little more usable range out of the Z axis. I'm working slowly, so probably another couple months until it is done.
    Jul 2011
    103
    Arizona here. My machine has been up and running for a couple months now. I use it quite often every week.
    Apr 2011
    Chandler, AZ
    Jul 2011
    103
    Quote Originally Posted by bjesson View Post
    Chandler, AZ
    Woah, wait a minute. Me too. What cross streets?
    Aug 2011
    53
    Anyone in Texas?
    Apr 2011
    Didn't realize we needed to add our completion status:
    Ariozona, first Momus completed March of 2011. Machine paid for itself within 1 week.
    Second Momus ETA: March 2012
    Jul 2011
    I'm in Santa Clara, CA.
    I have all the metal work done, the bottom part of the base is done, and I'm just in the process of painting it now. The cover has kind of been put off until I have the main part of the machine together. Will try to post some pictures soon.
    Patrick
    Aug 2011
    53
    It looks like there are several all over the map. I'm in Waco, Tx. The metal and wood are complete. I just finished the epoxy floor and will start looking for sources for the electronics. The epoxy floor turned out super smooth and flat. I was a little worried about how it would flow, but it worked great.
    Apr 2011
    41
    I'm in Wisconsin. I have my base completed minus the top and 75% of the metal done. can't wait to see it all together
    Apr 2005
    1268
    I'm in Spartanburg South Carolina!!! Howdy Yall!
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    Dec 2006
    202
    For the past few years I've been bouncing back and forth between Providence, Rhode Island, and Cambridge , Mass. Back in Providence at the moment. I also spend some time hanging out in Austin, Texas. Headed there tomorrow.
    I designed the original Momus machine somewhere back around 2007-2008. Built it between 2008-2009, and then took another year to get the plans put together. I'm currently working on version 2.0, a full update to the original design. Got the prototype machine under power yesterday. New plans coming very shortly.
    -Bob
    Jan 2006
    23
    All right - I'll be the first Canadian on this thread ... there must be others.
    I'm in Vernon, BC - Canada
    Charlie
    Mar 2009
    6
    Port Orchard,WA here land of liquid sunshine
    May 2011
    47
    Smile
    Salinas Calif.
Page 1 of 3 123
  1. Where's your PC Located
    By dobrientruckers in forum Commercial CNC Wood Routers
    Last Post: 11-27-2009, 11:55 PM
  2. HOW MUCH is my shop worth.. located in NJ..
    By squale in forum Uncategorised MetalWorking Machines
    Last Post: 10-17-2009, 03:22 AM
  3. Trying to located a type of cad file or even pdf
    By mcraig79 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-19-2008, 04:11 PM
  4. CNC foam cutter located in UK
    By chris_bean in forum CNC Wire Foam Cutter Machines
    Last Post: 08-30-2008, 05:43 PM
  5. Anyone Located in Chicago
    By turbo411 in forum Mentors & Apprentice Locator
    Last Post: 01-03-2007, 02:13 AM
