586,060 active members*
4,592 visitors online*
Results 1 to 18 of 18
    Dec 2011
    Linistepper v2 problem
    Hello all. I have problem my stepper goes one direction when LPT cable not in PC. If i put cable to PC stepper stop roatating. Why? What to do? Thanks.
    May 2005
    1397
    First, I don't see how that is a Linistepper v2 problem... it sounds like the driver is running the motor just great.
    If you are using the old, old, old version of the 4 axis board, with the pulse circuit attached, then that is exactly caused by the intended operation of the pulse circuit. It is diving the x step pin with a resistor, so the parallel port will overcome the pulse signal when it is plugged in. Remove the resistor R9 and the pulses won't get to the x-step line and it won't rotate when not plugged in.
    Or did you mean that it will not move at all (even when commanded by the PC) when the LPT cable is plugged in? In that case, the port setup or wiring is probably the problem.
    MUCH more detail required for accurate answer.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Dec 2011
    Quote Originally Posted by James Newton View Post
    Thanks for your reply. I haven't used breakout board. STEP and DIR wires I connected directly to LPT port. When I plug LPT cable I can control stepper motor. Your post help me understand what is going on.
    May 2005
    1397
    RN1, the 3k3 network resistor should be pulling the step line low when the LPT cable is not connected. Check solder connections or remove the PIC and check for 3.3K Ohms between the step pin and ground.
    Dec 2011
    I used posix layout.
    May 2005
    1397
    Quote Originally Posted by DjD View Post
    Ok, so you are NOT using a Linistepper V2 then... you are using a Posix Linistepper which isn't a board layout we sell in the kit. Our version has the pull down resistors which prevent this problem. If you are using the Posix, you need to keep the cable connected or you need to add a pull down resistor of 3.3k ohm between the step line and the ground.
    Dec 2011
    Sorry I'am write to late. Thanks for your reply, now I fixed this problem and I discover another: I power on linistepper, it is idle and two transistors getting very hot. Why it is hot when I do nothing?
    May 2005
    1397
    This would be normal for any stepper driver. At any given point, two of the 4 transistors would be on, depending on which step you have stopped at. On the real linistepper, there is a low power hold line that can be engaged to reduce power when holding. I don't know if that was included on the Posix design.
    Dec 2011
    How to make a low power hold line in posix designed board? Also, what settings use in TuboCNC?
    May 2005
    1397
    I guess you would want to ask posix and the support forum at TurboCNC.
    Dec 2011
    Okay I ask. Thanks.
    Dec 2011
    Hi James. On posix layout with linistepper v2 firmware I found "enable" pin. Where should I connect it on BOB? How to configure Mach3 to work "enable"? Thanks.
    May 2005
    1397
    Hi. First, you probably don't need to connect that to the PC unless you need to reduce drive power while holding between jobs. It just needs to be set for full power by connecting to ground or +5. See this page for the correct setting: techref.massmind.org/techref/io/stepper/linistep/lini_use.htm
    If you do need it, it just needs to make it to an output pin on the PC parallel port. I'm not sure which BOB you are using, so I can't tell you exactly how to do that on your BOB. Then Mach 3 needs to be set to bring that pin to the correct level when running a job, and back when it's not. Check the Mach 3 documentation for information on how to do that.
    Apr 2010
    32
    Cool Re: Linistepper v2 problem
    hello i don't know what is the problems to thisv2 linistepper i'm doing ,perfectly running every press on my keyboard direction jog button but for starting to play the entire gcode ,my circle is really in a right shape for 0.1 deep z axis then going down to 0.2 deep another circle,now the circle is not on correct position a bit exceeded and destroying the first circle. there's any relation to 3.3 resistor why i encounter mis position
    May 2005
    1397
    Quote Originally Posted by levon18lopez View Post
    Sounds like missed steps because of cutting too much in each pass? Try going down by 0.05
    Apr 2010
    32
    I have also just like that ,spindle trigger it self and x axis going to left ....when power supply is switch on.
    Apr 2010
    32
    vcarve calculated the right for me even far down,, but why it missed .......... llini stepper is direct to my computer .... no buffer ,, i used pmnimo 4 axis beakoutboad
    Apr 2010
    32
    Can be possible to convert linistepper into any bipolar stepper drive just like l298 can i connect. recently i tried to connect the l298 drive to linistepper motor input, i'd jog it but only vibrate a bit.then my wet finger touch the l298 input that center ,i'd jog left and right, now it's working.... big problem is putting your wet finger under the pcb ....i thought that missed step can be avoid with high torque bipolar drive but same resolution just like linnistepper
  1. Linistepper new board
    By salvado in forum Open Source Controller Boards
    Last Post: 05-20-2016, 12:33 AM
  2. need help on upgrading a linistepper
    By carl benz in forum Open Source Controller Boards
    Last Post: 08-17-2012, 04:53 PM
  3. linistepper over heating need help
    By kmist in forum Open Source Controller Boards
    Last Post: 04-11-2011, 01:19 AM
  4. Linistepper in C
    By hazimin in forum PIC Programing / Design
    Last Post: 01-24-2011, 03:34 AM
  5. Linistepper
    By tante in forum Open Source Controller Boards
    Last Post: 12-19-2005, 04:24 PM
