Just a Quickie! Modify Post.
I went into the debug mode and did not see an obvious entry to change, so here's the question.
How do I make the post not repeat the spindle speed on each and every operation with the same tool. There are times when that may make the speed posted 30 or 40 times within the same tool and making changes is nearly impossible.
Just want the speed posted when there is a change or at tool changes.
Thanks in advance------Mike
