586,599 active members*
3,625 visitors online*
Results 1 to 8 of 8
    Dec 2005
    34
    One of my drivers burned.
    One of my Python Digital motor drivers is gone. These drivers were made by “WWW.CNCbyDesign.com that doesn’t exist anymore and I lost one of them. If anyone knows about these motor driver boards (Model#: B508) I am attaching a pic. I ask you to help me either find where to buy them or if you have some of these to sell I will buy it from you. Thanks.
    May 2005
    1397
    What are the specs? Maybe we can help you find an equivalent.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Dec 2005
    34
    Specs.
    This is a two-phase Bipolar motor controller 20-50VDC , 35Khz , Power supply: 3 to 16 amp unregulated, 1.5 to 8.0 amps per phase, Enable, Step, direction Full/Half
    I am using this to control a 1200 Oz/In stepper motor (about 6 A).
    May 2005
    1397
    I would very much recommend you replace that with a geckodrive. Nothing else is going to reliably manage that much power.
    Dec 2005
    34
    Thanks.
    Thank you.
    Dec 2005
    34
    Quote Originally Posted by James Newton View Post
    I did it, I bought a couple of Geckos 201x. After I read the manual they have in line I replaced the X and Y axis with the two new drives. Something is note right. I tested the drivers with a small motor and it went very wobbly. I started changing the "motor turning" settings on my Mach3 program to try to avoid it but had no good results, same jerking. Any idea? Thanks.
    May 2005
    1397
    Contact Gecko support.
    1695
    Did you set the current properly?
  1. I burned a motor driver.
    By on7tim7 in forum Want To Buy...Need help!
    Last Post: 12-13-2010, 09:54 PM
  2. burned on ebay by modularcnc ?
    By dertsap in forum Complaints and Praise Discussions
    Last Post: 01-07-2009, 02:00 PM
  3. Bridge rectifier burned
    By danielm in forum CNC Machine Related Electronics
    Last Post: 04-08-2008, 11:45 PM
  4. Led light stack burned out on SL-10
    By Edster in forum Haas Lathes
    Last Post: 10-06-2007, 12:27 AM
  5. Burned!!!
    By Steve@Reliance in forum Community Club House
    Last Post: 06-25-2006, 09:01 AM
