586,052 active members*
3,935 visitors online*
Page 2 of 72 12341252
Results 21 to 40 of 1431
  1. #21
    Quote Originally Posted by LeeWay View Post
    I just bought some nice Echain. Now it would certainly take some time, but one could print the parts to make a mold and then use resin to cast them.
    Okay, Hoss. I won't post every time my brain lights the bulb over my head.
    Glad I am waiting on mine a bit. With your noggin working on these as well, there will surely be some profound insights for those building after you.
    All ideas welcome, keep em coming.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  2. #22
    Feb 2006
    7063
    Quote Originally Posted by lcvette View Post
    That video is amazing, i would love ro find some more information on what is actually happening to produce that part, hard to understand without knowing any background on it. it looks like there is a glass lens and as it is pulled up out of the material it somehow tranfers the design patterns in slices maybe? kind of like an MRI machine.. CRAZY watching it happen.
    any more info anywhere?
    Chris
    SLA machines have a vat of liquid polymer resin, and the part is "drawn" in thin layers with a laser, right at the surface. The laser cures the polymer, changing it from liquid to solid. In most such machines, the table on which ti part is drawn starts out at the surface, and submerges as the part grows upwards. The process can produce nice, accurate parts, with a resolution on the order of 0.001", but SLA machines are expensive, and the parts take a loooong time to run - run times of days are not unusual. But, they are great for making prototype parts to "test" a design, without the expense of cutting a mold.
    Regards,
    Ray L.
  3. #23
    Jun 2004
    6618
    I just found a link for some material supplies. Don't know how they compare with pricing of other places.
    Materials | Bits From Bytes
    Lee
  4. #24
    3D printer supply on Ebay has a lot of 3mm filament spools, pretty good prices and all the colors of the rainbow.
    3d-printer-supply | eBay
    Hoss
  5. #25
    Nov 2009
    4415
    Nuri's site has a link to a great place too 3ders.org - 3D printing and 3D printers news, trends and resources.
  6. #26
    Quote Originally Posted by Fastest1 View Post
    Excellent! gonna take weeks to read thru all this stuff.
    Hoss
  7. #27
    Jun 2004
    6618
    Very cool stuff.
    According to this link, we will want at least two extruders on a machine.
    3ders.org - Dissolvable support material used for 3D printing gearbox and Hilbert Cube | 3D Printer news
    One for printing desolvable supports.
    Lee
  8. #28
    Oh man this is going to get mental!
    Gotta work pva into the mix now.
    Hoss
  9. #29
    PVA looks tough to find yet but Makerbot carries a big spool.
    MakerBot® Water Soluble PVA - 1lb coil - 3mm - MakerBot Industries
    ProtoParadigm has a couple cheaper smaller sized spools to get your feet wet first.
    https://www.protoparadigm.com/products-page/other-3mm/
    They both have PVA in 3mm and 1.75mm.
    Hoss
  10. #30
    Chris
    They have a great 3D Printing Basics page on 3ders.org.
    Videos shows several different types of processes.
    3ders.org - 3D Printing Basics | Beginner's guide | 3D printers
    Hoss
  11. #31
    Jun 2004
    6618
    I also saw a link to where they can use polycarbonate, but as I suspected, it has to be dried first for best results.
    Lee
  12. #32
    Feb 2004
    1311
    I bought a 5lb spool of 1.75mm black PLA from ultimachine.com yesterday. I thought I'd get started with the finer stuff. I've read that it is a bit easier to melt and easier to get good results up front.
    cheers,
    Michael
    EDIT: should have been PLA not PVA
    Reelsmith, Angling Historian, and Author of "The Reelsmith's Primer"
    www.EclecticAngler.com | www.ReelLinesPress.com
  13. #33
    Quote Originally Posted by mhackney View Post
    I bought a alb spool of 1.75mm black PVA from ultimachine.com yesterday. I thought I'd get started with the finer stuff. I've read that it is a bit easier to melt and easier to get good results up front.
    cheers,
    Michael
    PVA? I got some ABS and PLA from them on the way but don't see PVA listed.
    Hoss
  14. #34
    Feb 2004
    1311
    Typo, meant PLA, fixed the original post.
    Michael
  15. #35
    Jun 2011
    I'm somewhat intrigued by designs like this one
    3ders.org - The ORD Bot 3D printer platform using MakerSlide linear bearing | 3D Printing news
    Basically all you really need is a 3 axis movement system with enough rigidity to hold the print head steady. Seems like it should be relatively come up with plans that could easily be made on the majority of CNC machines that people in the forum are using.
  16. #36
    That's pretty neat.
    Yeah I've seen all sorts of platforms researching these printers, seems to be a popular mod
    to make your own frame.
    The extruder isn't very heavy so the frame doesn't have to be super stout to support it
    and yet still is plenty rigid enough for accurate printing.
    I see myself expanding the X axis for making bigger prints.
    Hoss
  17. #37
    My rods and allthread showed up so I can cut them to length and get the Prusa frame built now.
    The electronics are due tomorrow but they'll all need soldered together first.
    Maybe get it going this weekend.
    Pics and video to come, nothing step by step or anything, they already have a very in depth
    instructional pdf that shows every step of the process.
    Time to get to work.
    Hoss
  18. #38
    Jun 2004
    6618
    Can't wait to see you going on this, Hoss. I was just considering some of the software. While Mach 3 may play nicely as a 3D print control, the CAM's I use won't really. Addition rather than subtraction being what is needed for the Gcode.
    What software will you use on this? It would help to get a step up on the interface with this.
    Thanks.
    PS. Here is a little better forum or at least more active than the first link I posted.
    http://www.bitsfrombytes.com/usd/forum
    Lee
  19. #39
    Jun 2004
    6618
    Also saw this.
    [ame=http://www.youtube.com/watch?v=KGrkWFTbmQw&feature=player_embedded]3D Printing Autodesk 123D Beta Models with MakerBot - YouTube[/ame]
    Do we really need a second head for supports? While I am sure it would come in handy, it would complicate the project. That complication might be worthwhile though.
    Lee
  20. #40
    I'll be using ReplicatorG too for both, that's what comes with the H1.
    I use Alibre for 3D and already checked that the stl from it opens in repg.
    Have to get into it later in more detail.
    A dual head will be more complex but I won't worry about that right now, have to
    get good with one head first.
    Hoss
  1. mhackney's 3D Printers
    By mhackney in forum 3D Printer / 3D Scanner Discussion
    Last Post: 04-04-2014, 09:17 AM
  2. ROBO 3D Printers
    By CNC_Kid in forum 3D Printer / 3D Scanner Discussion
    Last Post: 01-13-2014, 09:13 PM
  3. Why have 3D printers in the classroom?
    By cncadmin in forum 3D Printer / 3D Scanner Discussion
    Last Post: 10-23-2013, 04:10 AM
  4. 3D Printers why so quite on here?
    By xairflyer in forum 3D Printer / 3D Scanner Discussion
    Last Post: 07-17-2012, 04:55 AM
