586,116 active members*
3,442 visitors online*
Page 22 of 72 12202122232432
Results 421 to 440 of 1431
  1. #421
    My gregs is remote so I never had the two together.
    The hole on the gregs was actually a semicircle that I had to make round and a few other holes in it were
    actually not holes but they were easy enough to drill out.
    Don't remember if slic3r gave me a manifold error when I sliced the stl or not.
    Eh, still works.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  2. #422
    Jun 2004
    6618
    I actually drilled and tapped a 6-32 set screw to hold the Jhead in the Greg's.
    It was loose. It was tight in the Wade's. It came with set screw holes too, but not the Greg's.
    I did consider wrapping it with tape, but I wanted a set screw.
    Lee
  3. #423
    Here's a sneak peek at what I was working on today, a new ally bed to hold
    a 10x10 pane of glass and an ally lower to give more y travel.
    Nothing mounted yet, just laying there for a photo op.
    Hoss
    Attached Thumbnails Attached Thumbnails 101_0105_800x600.jpg   101_0110_800x600.jpg
  4. #424
    Aug 2010
    46
    well Hoss I have followed your lead once again and just ordered a Prusa from Maker Farm. The basement is being remodeled, so work on the G0704, is going to have to wait, so a nice small toy to keep me occupied will be fun. Keep the improvements comming, so us dummies can have something to aspire to............
  5. #425
    Oct 2011
    141
    Quote Originally Posted by hoss2006 View Post
    Hoss
    Hoss,
    What is the type of belt/pulley (# of teeth, MXL, etc) used on your RepRap? I want to order some from Stock Drive Products instead of printing out the pulley. I'm presuming the stuff on the RepRap uses belts with the least amount of backlash (I believe Trapezoidal teeth is less backlash than curvilinear but not sure)
    thx
  6. #426
    Yeah I had fun getting the mill making parts again, printing is a fun little side hobby
    but it's addicting.
    Hoss
  7. #427
    Mine came with 1/4" XL belts.
    Hoss
  8. #428
    Oct 2011
    141
    Hoss
    How many teeth on the pulley?
    thx
  9. #429
    I zoomed in on leeways thread 1st pic and it's 10 teeth, never counted mine.
    Hoss
  10. #430
    Apr 2004
    128
    new bed
    Hi hoss,
    is that a 1/4 x 4 plate that is bolted to the linear bearings?
    Sean
  11. #431
    Jun 2005
    34
    Hoss, is there any possibility that your pcb board can be cut down to fit the seemecnc printer. I want a hot bed.
  12. #432
    Dec 2009
    45
    For the heatbed, the circuit trace covers the entire board on one side. See http://www.reprap.org/wiki/PCB_Heatbed
    Some have mounted resistors on an aluminum plate to make a heatbed. There are posts about this in the reprap.org forum.
    HF X2 & 8x12; Shopsmith Mark V 520; USCutter MH-871; 50W Laser w/LightObjects controller; Sony A65; 3D Printers: MendelMax and custom one using Makerslide
  13. #433
    Oct 2008
    1632
    I believe most come standard with the XL but many are converting over to the GT2 if I remember correctly for better control and reduced backlash. I'm not sure how much difference it makes. I started to order some new belts and pulleys but heck it does pretty darn good with what it came with.
    Richard
    Quote Originally Posted by ImagineRobots View Post
    Hoss,
    thx
  14. #434
    Jun 2004
    6618
    I only ordered store bought pulleys when I hadd trouble with one of the OEM printed ones. The other one was fine, but changed both.
    The XL type with 10 teeth pulleys work great. Not bad on cost. You only need the pulleys if you bought from Maker Farm. He ships the XL belt with the SAE Prusa.
    I am sure I could print better pulleys than the bad original now, but there is the chicken or the egg effect at play here.
    Lee
  15. #435
    Quote Originally Posted by duzallcnc View Post
    Hi hoss,
    Sean
    Yes it is.
    Got a great price for a 10x10 tempered glass panel here.
    https://www.storesupply.com/pc-12925...els-67110.aspx
    Hoss
    Attached Thumbnails Attached Thumbnails 101_0113_800x600.jpg   101_0117_800x600.jpg
  16. #436
    Feb 2012
    60
    And the "freaking" begins ... :wee:
    Pat
    cnczone.com/forums/benchtop_machines/148568-yax2c-yet_another_x2_conversion.html
  17. #437
    timothy, as you probably saw in stephens link their PCB traces go almost all the way to the edges
    so trimming would be out but I've seen someone on the yahoo group that made room
    on their H1 for the same heatbed.
    Hoss
  18. #438
    Apr 2004
    128
    heated bed
    If you have a mill or an engraver the heated bed is a really simple milling job as there are no holes and such. The milling path can easily be drawn in a cad program. So no need for a PCB program and gerber converter. So you could easily make a custom size.
    Sean
  19. #439
    Nov 2009
    4415
    Look up heated silicone mats. I have one under a 14 X 14 piece of glass. You can have it made it any size. Flexible and self adhesive. Brisk Heat, out of Columbus, Ohio
  20. #440
    Oct 2011
    141
    Quote Originally Posted by Fastest1 View Post
    Interesting find but it's AC powered and cost $100 for a 12"x12" sheet.
  1. mhackney's 3D Printers
    By mhackney in forum 3D Printer / 3D Scanner Discussion
    Last Post: 04-04-2014, 09:17 AM
  2. ROBO 3D Printers
    By CNC_Kid in forum 3D Printer / 3D Scanner Discussion
    Last Post: 01-13-2014, 09:13 PM
  3. Why have 3D printers in the classroom?
    By cncadmin in forum 3D Printer / 3D Scanner Discussion
    Last Post: 10-23-2013, 04:10 AM
  4. 3D Printers why so quite on here?
    By xairflyer in forum 3D Printer / 3D Scanner Discussion
    Last Post: 07-17-2012, 04:55 AM
