586,043 active members*
3,809 visitors online*
Results 1 to 12 of 12
    Dec 2009
    30
    Stepper motor troubles
    Hello,
    I have a homemade cnc router. It has three pacific scientific motors and drivers on it. The problem I am having is as follows: as the machine runs a program, the motors will lock up and start to hum. It usually happens when the z axis completes a movement and the x and y start to move.
    I keep thinking that my power supply is not keeping up with the demand but it seems to happen no matter what speed I run the motors. I have had them as low as 200 mm per minute and they still do it. It happens randomly during a program run and does it on almost every program I try.
    Any help is appreciated,
    Dec 2008
    292
    What controller are you using and how many volts/amps is your power supply?
    Don
    Dec 2009
    30
    Quote Originally Posted by atwooddon View Post
    Don
    Don,
    Thanks for the resonse. I am driving the router with Mach 3.
    The motors are 7.5 amp bipolar motors that run at a max of 65vdc
    The drivers run at 12-75vdc. All three axis are the same.
    I am running this with a 36vdc 4.2Amp 150 watt power supply.
    Jason
    Hello,
    your power supply is much too weak. Together your Motors can pull up to 22.5A but your power supply is just capable of 4.2A.
    Christian
    Sep 2010
    717
    Quote Originally Posted by jchal3 View Post
    Hello,
    I am pretty sure you are experiencing stalling because of resonance. I had/have that too on my steppers. There are some fixes you can do mechanically; add a resonance damper like a flywheel or "hockey puck" for example (many other options too, do a search). Check these out for example:
    [ame=http://www.youtube.com/watch?v=UJjivsVwSsQ]Stepper Motor Damper Test. - YouTube[/ame]
    [ame=http://www.youtube.com/watch?v=mqCL7g4gwAU]Solving Stepper Motor Resonance Problem on CNC Lathe - YouTube[/ame]
    Hub
    Current build: http://www.cnczone.com/forums/diy-cnc-router-table-machines/264838-new-machine-desing-quot-cnm13-quot.html
    Dec 2009
    30
    Hub,
    My motors definietly sound like the motors in the video. This may be a dumb question but what is resonance and what causes it?
    I'm going to do a you tube search and figure out how to handle this.
    Dec 2008
    292
    I wouldn't ignore Christian's comment on your power supply either. 150 watts is not a lot of capacity to drive a CNC machine unless you are going very slowly.
    Resonance is basically a vibration that starts when the frequency gets just right for your machine. The dampers you see will basically stop the vibrations thru the drive system. They are simple to make and test. Hope that fixes your problem but I would bet on power supply first.
    Don
    Sep 2010
    717
    Yes you should also check that you have enough power and I agree that your 36V/4.2A PSU is most likely not enough.
    However I don't think that is your problem here.
    Here is what happens if you don't have enough power:
    - Not enough voltage: you loose speed
    - Not enough current: you loose torque
    Using microstepping might reduce resonance a bit. Are you using microstepping?
    The fastest way to test if you have resonence, is to add a hockey puck or similar flywheel to your stepper. It's easy to attach if the motor has a double shaft.
    Hub
    Dec 2009
    30
    I am using the microstepping settings. It is set to 25:1. My motors do not havea double shaft, so I'll have to get creative to figure out the resonanace issue.
    Sep 2010
    717
    If you are using (AL) 'flex' couplings just add the flywheel to the coupling (motor side of the coupling). Just as an idea..
    Hub
    Dec 2009
    30
    Hub,
    When you say AL flex coupling, is that the same as a lovejoy coupling. Basically one half for the motor, one half for the shaft, and a rubber spider in the middle? I think that is what you are talking about. and yes I am using that. I'll give it a shot.
    Sep 2010
    717
    Hub,
    Yes, that's what I meant. Sorry for the confusion.
    Hub
  1. 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors / Drives
    Last Post: 07-25-2010, 08:19 AM
  2. Integrated stepper motor? with built-in stepper motor driver
    By uirobot in forum News Announcements
    Last Post: 06-07-2010, 09:59 AM
  3. Beltdrive-stepper motor-stepper motor driver
    By Georg in forum Stepper Motors / Drives
    Last Post: 10-16-2007, 10:56 PM
  4. Troubles finding the right motor for the drive
    By Progger in forum Rutex Products
    Last Post: 07-16-2007, 02:28 PM
  5. Motor Troubles
    By tmd019 in forum Hobbycnc (Products)
    Last Post: 04-11-2007, 02:34 PM
