586,354 active members*
3,470 visitors online*
    Nov 2008
    73
    any1 seen a 12x36 lathe conversion?
    Hi all,
    I have a PM 12x36 lathe I am looking to convert to cnc and have be scouring the net looking for some examples to get ideas from but havent found much of anything. Has any one seen a similar lathe conversion? Got links?
    I have no doubt i can do it without examples, but it helps with ideas. I have scratch built a cnc plasma and a cnc mill so i am no stranger to cnc. I was going to scratch build a lathe but thought it might be quicker and easier to cnc the lathe i already have. Im still sorta up in the air on this, but either way, im in need and must build or convert asap.
    Jim
    Nov 2006
    40
    Did you check out zarzul's 13X40 conversion. Similar machines and you might get some ideas.
    13x40 lathe conversion
    Ron
  1. G4003 12x36 Lathe conversion Questions
    By breathe in forum Vertical Mill, Lathe Project Log
    Last Post: 02-17-2012, 01:59 AM
  2. Grizzly 12x36 G4003 lathe and tool post grinding
    By ThePigStye in forum MetalWork Discussion
    Last Post: 07-23-2010, 03:33 AM
  3. lifting a 12x36 lathe
    By casta-baga in forum MetalWork Discussion
    Last Post: 12-12-2009, 07:00 PM
  4. is there downlaodable manual for Atlas 12x36 lathe?
    By Goldhunter_2 in forum MetalWork Discussion
    Last Post: 11-26-2009, 06:32 PM
  5. EZ-CNC---Any1 seen this?
    By slp_prlzys in forum DIY CNC Router Table Machines
    Last Post: 08-14-2006, 10:50 AM
