586,121 active members*
3,156 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Help - Conquest 42 - turret fault
Results 1 to 5 of 5
    Feb 2012
    Unhappy Help - Conquest 42 - turret fault
    hi there i have a problem with my Conquest 42 powered the machine up , homed out , and it has developed a turret fault, the turret will unclamp but will not rotate to any tool stations any help or advice would be great
    Feb 2012
    update tried the turret reset as outlined in the manual and no difference turret unclamps and fails to do anything from there
    Oct 2009
    51
    Seems like the turret index belt is broken. There is a pipe plug on the turret body, take the cover/guards off the turret body and you'll see it. look inside there and check the belt.
    Feb 2012
    it was the turret position sensors inside the turret housing that had gone down
    May 2007
    1003
    Quote Originally Posted by ashg1984 View Post
    Thanks for posting the solution to your problem. Too often people don't follow up. It helps those of us willing to learn.
  1. 115 turret fault
    By plastibob in forum Haas Mills
    Last Post: 01-29-2024, 09:56 AM
  2. Tool Turret Fault Alarm on TL-1 with no Turret?
    By Edster in forum Haas Lathes
    Last Post: 02-08-2010, 03:35 PM
  3. adjusting the turret on Conquest 42
    By dango in forum Hardinge Lathes
    Last Post: 11-05-2009, 04:41 AM
  4. Turret shuttle fault
    By jprobst in forum Haas Mills
    Last Post: 09-23-2009, 04:05 PM
  5. Appreciate Help - Duplomatic Turret Fault
    By Tony2pies in forum Cincinnati CNC
    Last Post: 09-01-2009, 04:56 AM
