586,321 active members*
3,614 visitors online*
Thread: tool change
Results 1 to 6 of 6
    Nov 2009
    30
    tool change
    Hello i have yang smv 1000 with fanuc 0md
    every thing works will until i changed my spindle bearings
    the machine is no longer changing tools
    the broplem is that the cursle do not come to take tool
    it begin to read the 9020 macro
    and when it reach M82 the machine keep waiting with no action untill error comes
    i tried to put M82 ,M81, M83 from mdi but nothing happened
    Jun 2008
    1511
    Do you have a manual that specifies what M82 is used for?
    Stevo
    Nov 2009
    30
    yes 82 : arm forward
    83 : arm backward
    i tried to press on the air switch manually the arm(cursle) worked will
    but in mdi or m6 nothing happened
    Sep 2010
    1230
    Quote Originally Posted by Reyad View Post
    83 : arm backward
    See if power is switching to the relay and then via the relay to the solenoid that controls the pneumatic valve for M82. The error would probably be due to a proximity switch not being made in a timely manner that confirms the action launched by M82 has been completed.
    Regards,
    Bill
    Aug 2011
    79
    Hello, Just guessing but since you just changed the spindle bearings. Look to see if the spindle is trying to orient. A prox.switch is often used to check that. M19 and M20 are often used as commands. Does the spindle even try to orient? Fanfan
    Feb 2007
    314
    where exactly in the macro does it stop?
    In MDI, M81 M82 M83 cannot be commanded without calling M86 before
    M86 enable ''tool change function''
    M87 end of tool change.
    I have an hardinge vmc 1000 with fanuc 0M-D i think it is almost exactly the same machine. But maybe what i said does not make sense for you.
    On my machine, no matter if orientation is not set correctly, the carousel can go out. But if the Z axis is not at the home or the second reference point(G30). The carousel can't go out. There is a switch that confirm z axis is at the second reference. On my machine, it is input X20.3 but i don't know if the similitude between our two machine is extended to the ladder.
    If you have the electric diagram, find the output to activate the solenoid valve for the carousel, and in the ladder, find the row that activate this output, you will see what is missing to activate the valve
  1. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  2. Bridgeport interact 412 tool changer does not slow b4 tool change
    By RMARCH in forum Bridgeport / Hardinge Mills
    Last Post: 11-12-2013, 10:50 PM
  3. Replies: 4
    Last Post: 02-01-2011, 03:10 PM
  4. Replies: 0
    Last Post: 02-14-2010, 07:26 PM
