I finally got my Joe's 2006 running this past weekend. HCNC Pro Board, 305oz steppers, Mach3. No knowing much about cnc's and after spending hours and hours trying to set up the software and etc. I finally got some test cuts made. I noticed right off that a 5" x 5" square ended up around 4.875" x 5.125". Back to the software I went, adjusting this and that. I then slowed the machine down to a crawl thinking speed was the problem. Again, same problem replicated. I also noticed on some squares that the last corner didn't close. This only happened about 50% of the time.
It finally hit me that I never checked to see if everything was square, perpendicular, etc.
And so I ask.... what is the easiest way to check all this?
