586,076 active members*
3,874 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > open source Atmel/arduino PID motor control
Page 13 of 13 3111213
Results 241 to 250 of 250
  1. #241
    Dec 2014
    18
    Re: open source Atmel/arduino PID motor control
    The TRIAC is driven by a MOC3022.
    By the way, if I look at its input (pin 1) with an oscilloscope, the signal remains the same whatever the pot position.
  2. #242
    Mar 2009
    533
    That certainly is not right. Your zero cross detector is suppose to sync with your line freq. Are you triggering your 'scope to the line freq? Else it will stay the same if it triggers with itself.
  3. #243
    Dec 2014
    18
    No, my scope doesn't support such high voltage.
    The signal shown previously is the Arduino's input.
  4. #244
    Mar 2009
    533
    I would use the Arduino input (ZC) to also trigger your 'scope and then 'scope your pulse output of the Arduino, which should move position with pot rotation.
  5. #245
    Dec 2014
    18
    I am afraid I don't know how to do that.
  6. #246
    Mar 2009
    533
    Have you used EXT trigger?
    Must be a front panel jack for an external trigger. You would this jack to connect to the ZC signal going to your Arduino input. Then set your trigger mode to external. You monitor on channel 1 (or 2) the Arduino output pulse.
    I don't have your type of 'scope so I can't give specific steps to follow.
  7. #247
    Dec 2014
    18
    Oh I see !
    The pulses are fixed when the pot is at a low value (around 100) but are scrolling when I raise it.
  8. #248
    Mar 2009
    533
    So the pulses do move relative to the zero crossing signal. The next step is to figure out why the motor doesn't change rpm with the pot change.
  9. #249
    Jul 2019
    Hi all,
    this project have a protection about motor stuck or over current or not?
    Thanks.
  10. #250
    Mar 2009
    533
    The protection is a fuse in the motor wiring. The fuse should be sized such that if the motor stalled the fuse will blow. This fuse amperage selection will vary depending on the motor selected and its current ratings.
  1. CNC Controller with Arduino - open source
    By Christian Knüll in forum Open Source Controller Boards
    Last Post: 12-22-2012, 10:46 AM
  2. Arduino PID Motor speed control for router
    By EL34 in forum CNC Machine Related Electronics
    Last Post: 12-02-2012, 11:34 PM
  3. Open Source Spindle Control
    By rcpilot82 in forum Open Source Controller Boards
    Last Post: 05-27-2011, 10:25 PM
  4. EMC2 (Open Source) Plasma Control w. THC
    By rugludallur in forum Waterjet General Topics
    Last Post: 07-19-2006, 09:25 PM
  5. Any open source or cheap driver for bipolar motor 6 Amp, 2.7V??
    By berryCR in forum Stepper Motors / Drives
    Last Post: 06-10-2006, 05:43 AM
