586,076 active members*
3,814 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > open source Atmel/arduino PID motor control
Page 4 of 13 23456
Results 61 to 80 of 250
  1. #61
    Aug 2006
    157
    I was pondering ordering the MOC 3023 instead of the MOC 3021 I was going to order a few for future projects . the only difference i see is that the 21 fires the led at 5ma while the 23 is 15 ma does anyone have an opinion on this
    thanks guys
    I should have all the peices at the latest nex monday. so hopefully one of us will have pics of a working model soon now that there are 3 going at it
    Tim
  2. #62
    Aug 2006
    157
    Ok since i am new at electronics i decided to go through the circuit so i understand it. I then decided to post it here so perhaps others can learn
    So first lets look at what we want o accomplish (i may not be correct looking for others input on my rudementary understanding)
    We have a hobby router and want to be able to control the Router. I have a small rigid router.
    on Digital Pin 4 the arduino is sending a signal to an octocoupler
    Octocouplers are used for "Galvanic seperation" In laymen terms it keeps the low voltage microcontroller side of things seperated from the live 110 or 220 volts
    An octocouple works in this manner.
    It has an led in it that flashes or turns on a steady brihgness that is picked up by a phototransister. Like the lights you may have on your house that detect motion but this detects light. Think of it like driving into your driveway at night with the headlights off and pulling up to your garage. Your garage has a light sensor. when u turn your headlights on it pens the garage door. You want the sensor to do it instead of hooking 110v to the body of your car and dying.
    so the arduino flashes the LED in the optocoupler which creates a circuit allowing voltage to flow through a TRIAC.
    The TRIAC is basically a relay. It can hanlde more amperage than the optocoupler.
    So the 3volts from Arduino turns on the Optocoupler switch , which then turns on the Triac switch. allowing 110v to flow and turn your router on.
    Then there is zero crossing detection. which i am reading about now .......................
  3. #63
    Aug 2006
    157
    Quote Originally Posted by mmcp42 View Post
    here's the zip of the EAGLE files with LCD added
    rather than including the LCD itself on the shield I have shown a 16-pin header
    do check the A and K connections, the original (from OP github) had them the wrong way round
    I've also attached the files without the LCD
    hate to be a pain but do u have one with the components labeled. IM going throgh it by hand but want to make sure i have it right
  4. #64
    Dec 2010
    Eagle uses layers, if you show the tName layer you will see the names, tValues shows the values
  5. #65
    Dec 2010
    Now
    if I was building this from scratch, especially if I was brewing my own 'duino, I'd change some of the pin assignments
    currently there's no (easy) way to upload software to the chip
    so
    I'd free up D1 so we could use D0 D1 for FTDI comms
    I'd also look at freeing up D11, D12 and D13 so we can use ISP
    simple enough to change the hardware and the software
    I wonder why the pins used were chosen?!?
  6. #66
    Dec 2010
    here's my attempt on a stand-alone
    pins re-assigned
    a) to make routing easier
    b) to free up SPI
    c) to free up FTDI
    enjoy
  7. #67
    Aug 2006
    157
    Thanks for the work mike
    I ordered 10 of everything on the board. Inlcuding 5 atmega chips with sockets. I spend a whopping 65 dollars lol. I agree on the pins. My plan was to remove the chip to my uno board for programming. But your approach is good also. I should have everything end of week or next week. I am going to try to make the pcbs using the laser etching method.
    If it works and anyone want a board ect i bought extra stuff since i have a lathe, mill, plasma and a few other hoebuilt things laying around. I am really glad i found this thread. I havent posted on cnczone for years. Since i built one of my machines probably 6-7 years ago. I also ordered all my stuff for the 3d print head i been wanting to do.
    This thread should get exciting soon. Whats your plan for building mike. Are u gonna do the pcb you designed or the newer with easier updating of the chip.
    I also designed my box to have an outlet. So that way i can plug other things into the control. I am going the route of a led rpm. That way a painted white line can do the control.
    See ya soon
    Tim
  8. #68
    Dec 2010
    I will use the "new" pins on a standalone board. Tell me more about laser etching. I'll put up the full eagle files later
    Cheers
    Mike
  9. #69
    Dec 2010
    ok
    here's my contribution
    zip with EAGLE files for a stand alone controller
    do run the ratsnest command to lay down the ground plane before you etch
    this board:
    a) untested
    b) on-board PTH Arduino
    c) untested
    d) FTDI
    e) untested
    f) ISP
    g) untested
    h) pins shuffled to make it easier to route the board
    i) untested
    j) sensor deliberately vague
    - uses analog pin
    - allows for IR or Hall effect
    - allows for temperature sensor
    k) untested
    l) single sided
    m) did I mention - untested
    you WILL need to change the software to match the pins used
    I have allowed for 3.5mm screw terminals for the heavy duty mains connections
    I have allowed for smaller screw terminals for external components
    - M3 interface
    - M3/Manual switch
    - On switch
    - sensor
    - 12 volts AC for zero crossing detection
    FTDI and ISP are simply headers as you won't be changing the software all the time (will you?)
    the LCD is brought out to a 16-pin (ok 2 8-pin) header
    you could just use a suitable screw-connector if you prefer
    I will almost certainly use this for a reflow oven controller
    but the same principal will work for a spindle controller
    if anyone has any comments or feedback I would be delighted
    caveat emptor
    enjoy
    YMMV
    and finally
    THERE ARE LETHAL MAINS VOLTAGES ON THIS BOARD
    IF YOU KILL YOURSELF DON'T COME RUNNING TO ME!
    Attached Files Attached Files
  10. #70
    Aug 2006
    157
    man that is great work mike, I take it your not building one for a cnc control. I really like how this board will be able to be used for so much. By just changing the triacs for more or less power.
    I am hoping to also use it as a heat controller for my 3d printer i finnally collected all the peices for and for the router speed.
    I will post build pics when i get all the peices from digi key. It will also be my first etch of a pcb board. I am not sure if i am goingt o try the laser printer etch method or just mill it on my grilly. Guess trial and error will see
    thanks for the Eagle input mike. I am new to this so I am glad you came along to help
    I was curious if you could better explaint to me how the zero cross works, And if i can use 12 volt dc instead of a transformer then the rectifier.
    Tim
  11. #71
    Dec 2010
    Tim
    first off you can't use 12 volts DC, that defeats the whole purpose of the entire project!
    the zero crossing part works by raising an interrupt every time the AC crosses zero (hence the catchy name)
    you need this as the code will set a delay from the zero cross point before firing the triac
    that's how it controls the speed
    to go faster fire earlier
    to go slower fire later
    the triac turns itself off when the voltage drops to zero
    so it needs to be turned on again every half cycle
    hope that made some sort of sense!
  12. #72
    Aug 2006
    157
    yes sorry for the dumb question.
    I assumed the 12 volt ac transformer, going into the bridge rectifier made it into dc. So i thought i could cut out the transformer. My bad. Again I am leraning (wedge). Thanks for all the help.
    I ordered 5 pcbs. so i am goingt o experiment this weekend on etching or milling them
  13. #73
    Apr 2006
    3498
    Why are you using "12 volts AC for zero crossing detection"?. why not directly from 220VAC?
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  14. #74
    Dec 2010
    Quote Originally Posted by timmyb199 View Post
    there are no dumb questions!
    it would be DC if it had more circuitry
    the full wave bridge rectifier (4 diodes) and the following components simply give one pulse per half cycle
  15. #75
    Dec 2010
    Quote Originally Posted by Khalid View Post
    two answers
    a) cos that's what the circuit from the OP did!
    b) because the lower voltage means the following circuitry only sees a much lower voltage (~17 volts max)
    now, I would ask "why 12 volts"?
    It must be tempting to use 5 volts AC (7 volts peak) instead which is just enough to drive a 5 volt regulator!
    hmm now there's a thought!
  16. #76
    Aug 2006
    157
    I got my peices from digi key, i forgot to order a transformer, is there anything i can subsititute? will post pics of build tongiht
  17. #77
    Aug 2006
    157
    I guess the better question is the only part i dont understand is the zero cross thingy. Maybe if i better understood whats it is doing i could find a substitute. im gonna dig in my peices of electronics but seems everything i have is ac in dc out
    this is interesting seems simpler will keep digging
    http://playground.arduino.cc/Code/ACPhaseControl
  18. #78
    Aug 2006
    157
    I have an issue i am running into. I loaded the libraries but it wont compile and i get errors. I am curious when u see this mike if you got a good compile
  19. #79
    Aug 2006
    157
    Ok got a good compile now onto the board and circuits
  20. #80
    Aug 2006
    157
    Mike,
    I you stop in, do you have a .pde with code with updated pins. I cant get his to compile now and after 5 hours of trying to get the lcd i have to work with his i am losing my mind. I have a 16/2 lcd. I can get it to work but not with his library. Any help would be much appreciated
    Tim
Page 4 of 13 23456
  1. CNC Controller with Arduino - open source
    By Christian Knüll in forum Open Source Controller Boards
    Last Post: 12-22-2012, 10:46 AM
  2. Arduino PID Motor speed control for router
    By EL34 in forum CNC Machine Related Electronics
    Last Post: 12-02-2012, 11:34 PM
  3. Open Source Spindle Control
    By rcpilot82 in forum Open Source Controller Boards
    Last Post: 05-27-2011, 10:25 PM
  4. EMC2 (Open Source) Plasma Control w. THC
    By rugludallur in forum Waterjet General Topics
    Last Post: 07-19-2006, 09:25 PM
  5. Any open source or cheap driver for bipolar motor 6 Amp, 2.7V??
    By berryCR in forum Stepper Motors / Drives
    Last Post: 06-10-2006, 05:43 AM
