I have gained a lot of info here but this is my first post.
I am seeking input and criticism of my upgrade plan; I just purchased a very well made CNC matcutter with Galil DMC-1050 5 axis ISA PC card controller that is operated with proprietary software and not native gcode (can convert to their format but remains 2D).
I am going to use the machine as a 3D CNC router (spindle) and Laser engraver. The current components are:
Galil DMC1050 controller, (2) ICM1100 Interconnects), (5)Advanced Motion Controls B12A6 PWM Servo Drives, (4) Parker SM231AE Servo Motors, Elektro spindle w/VFD.
Options as I see it:
1. Mach3 & LPT1 wired in to bus or breakout board. (Can the ICM1100 be used as a breakout)
2. WinCNC & PCI Card wired to the ICM1100 (or do I need a breakout)
3. Upgrade the Galil to a newer card using Mach3 w/plugin (such as DMC1850) card wired to the ICM1100
4.?? You tell me.
It is a robust machine and I would like to keep a robust servo controller setup without breaking the bank. I already have Mach3, would have to purchase the rest of the equipment listed in the options.
