Im trying to figure out what servo motors I need for a new build I am currently planning. The machine is 3000mm x 1500mm and not sure which motors would be required to start/stop the gantry weight.
I am trying to use a servo setup from DMM Technology if possible (DMM Technology Corp.).
The Y axis including the Z axis weighs around 75kg and I would like to rapid as quickly as possible due to the size of the bed. The machine will use a rack and pinion (25mm o/d) and the X axis is geared 3:1 so every revolution the gantry will travel 25mm.
I have scoured the net and cnczone but I just cant work out what motor wattage/nm would be best and hope someone could spend a little time helping me out if possible.
Im quite happy to provide any other information if needed and would be very grateful for any help.
Thanks very much,
JJ
