586,061 active members*
4,414 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > suggestions for plasma table components
    Mar 2005
    53
    the table is going to be about 4x4. I have all of the gantry and table worked out, now i need help with component selection. I need to do this on the cheap, but am willing to sacrafice for some quility. the table will cost about 500 for all the raw materials. I want to spend about 1000 on all of the electrical. here is what i need suggestions on.
    1) stepper motor strength/brand
    2) breakout board brand
    3) stepper Driver selection
    4) plasma on/off relay board
    5) power supply output/brand
    6) gear reduction for rack
    7) Torch height control
    8) cooling fan cfm
    I will be using catia for cad, and mach 3. If you can thinkof anything else i need or am missing that would be good too. thanks for the suggestions.
    Dec 2004
    312
    if u want it cheap.. shop at ebay..
    gear reduction for nema 34 5 to 1 gear ratio is about 600 bux each fyi
