586,051 active members*
3,819 visitors online*
    Nov 2005
    Sending code to the Fadal CNC errors?
    Hi all
    Hope I have this in the correct forum..
    Were very new to CNC machining, we have a Fadal 4020 & using MS Hyperterminal to try & send post processing code made with Catia, however were getting the Noobie Blues.
    Were able to PU & TA text back & forth between through the hyperterminal, the problem arises when we try to send a program we created in Catia generating with fadal.lib extension to the machine, it only feeds one (1) line at a time (each time we give it the TA command it sends another line) looks like the end of line function is wacky.
    Is the MS Hyperterminal a waste of time?
    Any suggestions are greatly appreciated
    Tim
    4826
    I think Hyperterminal must be lacking the proper functionality for high speed communications, but I don't know why. There are many many other DNC utilities out there that will do the job properly. I started out using a simple program called Shadcomm (from the Millwrite engraving people), but now that I have OneCNC, I use their utility.
    I think OneCNC had a free to try DNC utility somewhere, with a nag screen , but I cannot find the link to it at the moment. You could contact the Florida office maybe they'll have a link for you.
    Nov 2005
    Thank you Sir
    I did manage to locate the download, will give it a try
    Thanks again,
    Tim
