586,485 active members*
2,550 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Problem with Fanuc 11M PC500:Watch dog alarm
Results 1 to 5 of 5
    Oct 2010
    131
    Angry Problem with Fanuc 11M PC500:Watch dog alarm
    hi everyone..
    I am machine-tech person...
    I got a problem with Fanuc 11M...
    Firstly it was stuck on boot with Bubble memory initialize:Error
    I initialized the bubble memory....
    It says bubble memory initialize:End
    than i have to reenter the parameters...
    i entered the No of axis
    option parameter 1 to 32 in hexadecimal
    everything is okay upto that point...
    but when machine boots, it boots okay and then it should show the main screen..
    But everything halts and screen shows PC500: Watch Dog Alarm. Motherboard shows E.
    1. Problem can be wrong option parameters entered...
    but we have a copy of Parameters and i tried to re enter the parameters 3-4 times....
    but same alarm comes again and again...
    2. Problem can be with motherboard or BMU(Bubble memory Board)
    I sent it for repair to 2 local Fanuc card repair specialist
    after checking they say everything is fine...
    I don't have spare BMU to test...
    What should I do now. Please help.
    Aug 2011
    2517
    perhaps try entering 0 for all option parameters (i.e. the option is not enabled)
    the theory is the machine may be checking something that has been turned on by the parameters. if you turn all of that off it may not have an alarm. then you can narrow down which parameter is wrong by entering 0 for just one of them. reboot, if still alarm enter parameters as before but 0 for the next one. if you still get the alarm with all options off then your problem is hardware related. maybe
    Oct 2010
    131
    forde11 thanks for the reply...
    already have done the same, but nothing problem is same.....
    Dec 2003
    24223
    Watchdog error usually means something with the firmware either main processor or memory, most likely M.B..
    Al.
    Albert E.
    Oct 2010
    131
    thanks "allk the man"
    We replaced motherboard and problem is solved now....
    but now after machine is ON, it shows hardware overtravel for all the axis...
  1. Fanuc 11M PC500 Watch dog alarm
    By Harmeet in forum Bridgeport / Hardinge Mills
    Last Post: 02-10-2012, 09:54 AM
  2. TOYODA -HMC-FANUC 11M - PC 500 WATCH DOG ALARM
    By rajesh_1355 in forum Fanuc
    Last Post: 08-08-2010, 05:10 PM
  3. Mazak QT-6T Watch Dog Alarm
    By flomatic in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-23-2009, 12:55 PM
  4. 920 Watch dog Alarm
    By jav40 in forum Bridgeport / Hardinge Mills
    Last Post: 02-18-2009, 05:07 PM
  5. Replies: 1
    Last Post: 11-17-2008, 01:00 AM
