Hello , I do not know a whole lot about metals , I am building an electric guitar and the leg rest will be made of "Im guessing" an aluminum alloy of some sort because of its lighter weight and strength.
here is my issue: I need to bend the alloy a specific way I have included my rendering of the guitar with this post so you can see the thin aluminum bar.
Which alloy should I use I was thinking 6061?, How should I bend it? the dimensions of the bar will be about .25" thick x 1.25" wide x 16 " long. Do you think .25 can be bent easily by hand will it cause problems when resting against the leg?
