586,060 active members*
4,563 visitors online*
IndustryArena Forum > CAM Software > Vectric > VCarve Pro - Roughing and Re-Roughing
    Apr 2009
    5516
    Here's a dilemna: You have a sign, for example, with a large field, and raised letters in an intricate font or artwork (a pocket with intricate islands). To get the best surface for the field you'd like to use the largest straight bit possible, say 1/2". The problem is, your final pass with your fine bit, say 1/16", would take forever because the 1/2" bit leaves a lot behind. You could use a 1//4" or 1/8" bit to do the clearance pass, but that would take forever too. How do you resolve this?
    I discovered a cool trick. In the above example using the pocketing toolpaths, select 1/4" as your finish tool, and 1/2" as your clearance tool.
    Now, do the same thing, instead select 1/16" as your finish tool, and 1/4" as your clearance tool. Then just delete the 1/4" toolpath that was just created.
    In this way, the first operation would be the 'rough' and 're-rough', and the last operation would do all the detail work. It's an extra tool change, but in many cases this would be way faster than using a small tool for clearance.
    This also works in Cut3D as well... saves a heluva lot of machine time!
    Jan 2009
    68
    Quote Originally Posted by louieatienza View Post
    No.. saves a heluva lot of machine time!
    A most valuable tip.
    Thanks, Louie.
    Nov 2010
    71
    I use VCarve Pro and love it. I can't imagine carving signs without it. That is a great idea! I'll have to give that a try.
    Mike Kearns
    mikeswoodsigns.com
  1. Need help with G68 roughing cycle.
    By g-codeguy in forum Fagor Automation
    Last Post: 02-13-2012, 05:18 PM
  2. Turning roughing
    By pinguS in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-23-2009, 11:49 PM
  3. 3-D roughing
    By mars13 in forum Surfcam
    Last Post: 05-23-2009, 11:38 PM
  4. Roughing Steel
    By Alex Westling in forum MetalWork Discussion
    Last Post: 06-12-2008, 04:08 PM
  5. Roughing program
    By blmmdes in forum Hypermill
    Last Post: 04-22-2008, 04:41 AM
