My first time using this forum for a quote, so I may mess up with the pic., but here goes.
I need quotations for 4 different drill plates. The picture attached is typical. All are 4" by 6" by 3/8" in thick. This is a first article, primarily for testing purposed, so CRS is the preferred material. I may even accept 6061, Alum. if the price is better.
Needs to be done on a CNC mill with all holes +/- .005. from a datum point on each plate. Outside edges of the plates are not critical so all four can be done from one set up on a larger piece of mtl. and then sawed to 4X6. I will provide cad files for each part, in your preferred format. At this time they are AutoCad drawings, .dwg. If you need additional information before quoting, please let me know.
Regards, D. Lee
