586,121 active members*
3,084 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > How much pressure on rack and pinion
Results 1 to 12 of 12
    Dec 2004
    312
    I'm wondering what is the force for a good mesh contact and long lasting wear?
    Is there a chart for it? Does the number change if the face width is different?
    Dan
    Nov 2006
    473
    Dan-
    Did you find an answer to your question?
    I am having problems with my cnc flame cutter, and i think the problem is that i am not pushing the pinion hard enough against the rack. I am going to install a air cylinder that pushes the pinion against the rack, this way i can increase the air ptessure to increase the pressure on the rack
    Steve
    24221
    Quote Originally Posted by DanOSB View Post
    Dan
    14-1/2" pressure angle is usually considered quieter operation, higher contact ratio and less backlash, the 20° has higher load carrying capacity.
    But there should be a method in place to make sure full mesh exists at all times.
    I have used the Rosta tensioners for the designs I have implemented.
    Al.
    Albert E.
    Apr 2004
    305
    On my plasma table, I am using an air cylinder to push the the gear into the rack, and using an adjustable stop to keep it from trying to push the gear into the rack too hard. I was noticing on my old table that if I applied a lot of spring tension to the gear rack, I could accelerate well, but you would see a bit more saw tooth on the cuts. With less pressure the gear would jump out on hard acceleration. So I figured with the adjustable stop I could really push some pressure on it, keep it from jumping out and also resolve the saw tooth issue.
    Dec 2004
    312
    What do you mean by saw tooth
    The rack isn't perfect flat so I wouldn't add a stop.
    I am planning on going air cyl route than rosta tensioner
    That's why I'm trying to find a force needed for it so I can adjust the regulator.
    Dan
    24221
    Post #4 shows the Rosta item.
    http://www.cnczone.com/forums/diy-cn..._backlash.html
    Al.
    Albert E.
    Nov 2006
    473
    I had some spare time today, and I cut off the old spring tensioner, and installed an air system on both sides of the x axis. It made a HUGH difference.
    Now to play with the air pressure and figure out how much pressure is enough.
    Steve
    Sep 2008
    140
    Hi Steve,
    Any chance of posting a picture?
    Thanks, Larry
    Nov 2006
    473
    Metalfixer
    I will post a picture later in the week. I cant get to the shop until then
    Steve
    Sep 2008
    140
    Hi Steve,
    Just checking back to see if you had time for that picture.
    Thanks, Larry
    Dec 2004
    312
    Was wondering what size cylinder did you use and aprox how much psi is it set for? How wide face is your rack and what dp?
    Cheers
    Dan
    Sep 2008
    140
    Any updates on this topic, before it heads off to page 2 of 83 ?
  1. calculatiing pinion size for rack and pinion setup
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 08-06-2015, 11:18 AM
  2. dual pinion rack and pinion anti backlash
    By johngalt47 in forum DIY CNC Router Table Machines
    Last Post: 06-12-2011, 04:04 AM
  3. Rack and Pinion- rack tensioned to pinion?
    By Rees Guitars in forum Linear and Rotary Motion
    Last Post: 05-09-2011, 06:05 PM
  4. rack and rack & pinion with off the self planetary gearbox
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 12-06-2009, 03:54 PM
