fadal VMC15/xt.
A technician repaired our machine a while ago - one of the drivers was shorting and he apperantly used the 4th axis card to make the machine work as xyz only. That technician dissapered and cannot be contacted.
A while ago another driver had been shot . i had both drivers repaired and also the motor ( the resolver had been damaged) and all are working now. But the JOG screen only shows x, y and z position - there is no A axis at all even when I insert the axis card ( the one with the 3 coax connectors on it ) whice I found was pulled out and laid on the botom of the control box.How do I put A axis on the screen again?
Also - when doing CS as requested by the control all the axes jerk with a loud thump but stay on - is this normal?
