We have a bridgeport series 1 that came with a Boss 8 control. We retrofitted the control with Geckos and EMC and its successfully machining parts.
The problem is that we have been unable to do climb milling - we always get a bad finish with gummed up material around the cut. We've tried playing with feeds and speeds until the cows come home to no avail. I dont have coolant on the machine but even when I use a spray bottle with kerosene or WD40 it really doesnt solve the problem. I am thinking maybe the spindle bearings are worn out. The machine came from a shop that left it around as a parts machine, so it's definitely possible its worn pretty well. When we got it, one of the boards in the Boss 8 was cooked, so it could also just be the machine sat due to that, not due to wear.
So anyway, is there an easy test I can run to check whether its the bearings? It does make a fair bit of noise when it's really cranked up to max speed (4k rpm). And if it is the spindle bearings, is it easy to get new ones or are they a specialized part? Is it something I could get from McMaster? How much $$$ to replace assuming I do the work myself (I've had the head apart before, no big deal).
