586,116 active members*
3,360 visitors online*
Thread: Taper macro
    Sep 2006
    222
    Taper macro
    Tool: D63mm
    taper 5 degree, 90mm distance, end diameter 210mm
    I have been doing circular interpolation for this miller. Because radius changes all the time, it have to be done by small lines.
    Program is very long.
    Is there possibility to use some kind of macro?
    Jun 2005
    142
    you can use a simple subroutine with common variables to step out in dia and length for each revolution...
    Sep 2006
    222
  1. Difference in Female Taper angle using Taper Cutter
    By Buntron in forum Material Machining Solutions
    Last Post: 06-07-2011, 06:53 AM
  2. Checking taper and gage-point using Fanuc Macro B
    By symbiosis in forum Parametric Programing
    Last Post: 11-01-2010, 07:00 AM
  3. NPT Taper-to-Straight-to-NPT-Taper Thread
    By bdyenter in forum MetalWork Discussion
    Last Post: 09-16-2009, 02:10 PM
  4. Macro Programming for Taper Bore machining
    By yaji63 in forum G-Code Programing
    Last Post: 05-22-2008, 04:26 AM
