Running my mill as XYZA and XYZC
I am starting to add a 4th axis to my mill.
The parts I want to mill would need to be milled on the 4th axis in C configuration (4th axis parallel to Z)
But I would like to be able to then tilt the 4th axis to A configuration so that I can finish the part with the 4th axis in A configuration.
Now the mechanical side of things is a challenge but I think I can get there. But how to work the software side of things?
Should I make a 5 axis configuration in EMC (I refuse to use the new name) and change a plug to connect the stepper to a different set of pins in the parallel port, or should I use a 4 axis configuration and make the changes to the gcode?
Mmmm, in writing this it seems to me that I have to somehow give the mill a new mill area to work in regardless of a 4 or 5 axis configuration so 5 axis would be pointless...
Any comments?
Sven
http://www.puresven.com/?q=building-cnc-router
