586,067 active members*
4,872 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Interact Series 1 mk 2 w TNC151b control
    Jan 2012
    Hi
    I have an interact series 1 mk 2 with heidenhain TNC151b control. I have just this morning started to test it with some ureol to check it is all in order before i launch it into active service
    Unfortunately there seems to be an issue with calibration or similar.
    I programmed it to cut a cube 85mm (using 16mm tool) in the X and Y and the depth of the block (45mm). However the end result is only 83.7 in the X and Y.
    After sometrial and error this morning have found the following
    If my code says start at 0 and move to 101 across the X the tool actually only moves 99.3 (hence the smaller square).
    If I then use the wheel to manually move the tool back to the 0 position it goes further than original 0 start point to leave a gap of 1.3mm between the tool edge and the original cut.
    any ideas, is this something i can fix or do i need an engineer to calibrate if, if so, anyone know a good one in the south east / east of england?
    thanks
    Gavin
    1121
    Hmmmmm
    possibly backlash parameter set too high?
    Does the machine run smoothly even when at rapid?
  1. bridgeport series 2 interact 4
    By dcchip in forum Bridgeport / Hardinge Mills
    Last Post: 05-01-2010, 01:27 AM
  2. Bridgeport Series 2 Interact 4 CNC Control Parts
    By Gnome in forum Bridgeport / Hardinge Mills
    Last Post: 03-28-2010, 01:53 PM
  3. Mach 3 control on Bridgeport Series 2 Interact 2 CNC
    By PeeBee in forum Bridgeport / Hardinge Mills
    Last Post: 09-23-2009, 03:23 AM
  4. bridgeport interact Tnc151B plc
    By hansdie in forum Bridgeport / Hardinge Mills
    Last Post: 01-12-2009, 10:44 PM
  5. bridgeport series 11 interact 11 hiedenhain tnc 2500 control
    By blackpalm in forum Bridgeport / Hardinge Mills
    Last Post: 09-20-2007, 05:21 AM
