HI all:
I am embarking on a CNC router build and have a few specific questions. If there are threads elsewhere that answer some of these just point me there.
This will be a machine primarily used for wood working as I already have a mill and lathe (no CNC). Working size will be approximately 30"(X), 20"(Y), 6"(Z), I am planning to use Misumi series 6 extrusions for the base, 425 oz-in steppers, ball screw drive (5mm pitch), supported rails for all three axis, 20mm for x and 16mm for Y and Z. I have the rails and ball screws on order from Linearbearings2008 (chai). The spindle will initially be a Bosch Colt router with option to update to a Kress or similar perhaps at a later date. Speed is not a big issue with the system. I am looking at basically a system very similar to the Fireball Comet system with a single drive for X and some redesign on the Z axis. I intend to use 1/2" aluminum plate for the gantry as they do, as well as for the Z axis. My background is primarily electronics but I have a lot of woodworking experience, a lot of exposure to mechanical engineering, some CAD skills and some self taught rudimentary machining skills (beyond just drilling holes).
So my questions are as follows:
--I am a bit unsure how to spec the size of the Misumi extrusions. I will be using the 30mm series to match the supported rails and they will help strengthen the assembly but what would people suggest as the basic size for rigidity and strength for this size router.
--I am considering reversing the motors and bringing them inboard of the assembly so that they are parallel to the ball screws and drive the ball screws with toothed belt and pulley drives. Several reasons, first to get them out of the way and reduce the footprint of the overall machine, second so I can change the ratio of the pulleys to get a finer step or more torque if needed, thirdly to help balance the load on the Z axis assembly. Are there any issues with this approach that people are aware of?
--I chose the 425 oz-in motors as kind of the sweet spot for steppers and what other systems this size seem to be using. Will they be adequate for this size system? Any thoughts there?
--I noticed a lot of the moving gantry type systems have the gantry sloped back (as in the Comet). Is there some pracical purpose for this or is it just for the cool factor. I can't see how it changes the travel one way or the other, but maybe it changes the angle of the forces on the bearings or moves the spindle over the bearings to move the center of gravity?
All help and comments are much appreciated.
Rob McC
