586,075 active members*
4,183 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Drill a hole through 1/4" dowel rod
    Jul 2011
    I'm trying to drill a 1/8" diameter hole, 5" deep axially through a 1/4" dowel rod. I'm using an aircraft bit which I trimmed down to 6". I tried the drill press, both conventionally and lathe-mode (work chucked, bit stationary) but still, too much slop. Even after making a jig with a drill guide bushing, I can't get more than 3" in. No matter how centered and squared up I get it, the inherent flex of the bit seems to make the hole wander off course and bust out the side. I guess drilling endgrain makes it even tougher. I can't help but think that even on a metal lathe this would be difficult because of the bit deflection.
    I'm thinking that running a bit in a tube/sleeve that follows the bit would help but that seems awfully involved for something like this.
    Any ideas?
    Sep 2006
    21
    Try starting with a shorter bit then switch to the longer one to finish.
    The shorter one won't deflect as bad and give you a straiter hole to start with.
    May 2010
    313
    Quote Originally Posted by Jack Burton View Post
    Any ideas?
    I'd suggest using a shorter bit and drilling in from both ends to achieve the 5"
    John
    Jun 2007
    3757
    Start with a center drill.
    The a stumpy 7/64 for a stable pilot hole, peck drilling
    The a 3mm drill to full depth plus more, peck drilling to keep drill unclogged.
    Then run the 1/8" drill through to finish.
    Run, say 2000 RPM.
    You might need to do it from both ends, at least with the initial steps.
    Apr 2007
    8082
    If this is a wooden dowel rod it has grain that does not usually follow the center of the dowel. The drill tip will tend to follow the wandering end grain.
    Select the dowel for the straightest grain structure you can find. Use the stiffest drill you can find. Cheap drills are usually fairly flexy because they have flutes that are ground too deep, or are made of metal that is not very rigid to begin with.
    If using a drill press, the table surface needs to be set as close to 90 degrees to the quill's center line as possible or it will start drilling the hole at an angle anyway.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
  1. Dowel Pin Hole Preparation
    By eliot15 in forum MetalWork Discussion
    Last Post: 07-31-2011, 03:54 PM
  2. Replies: 18
    Last Post: 03-21-2011, 11:28 PM
  3. Dowel Pin Hole Preparation
    By pearldiver in forum MetalWork Discussion
    Last Post: 12-29-2009, 06:28 PM
  4. How can I drill a 2" hole through a window?
    By garagefela in forum Glass, Plastic and Stone
    Last Post: 01-30-2007, 02:00 AM
  5. How to sharpen Dowel Drill Bits - Brad Point
    By bignimmer in forum MetalWork Discussion
    Last Post: 11-01-2006, 11:48 PM
