Originally Posted by
Dr_Mark_Vaughan
It sounds like you hve the wrong post processor selected. The people that supplied you with your router, and type3 should have supplied you with a post processor for the machine, if they haven't and type3 is genuine you may be able to get some support from them. You can get access to the post processor file, you will note an option there when you post code of change machine, type3 don't seem to provide instrcutions for this but by fiddling with some parts and viewing the posted code you can mod some of it yourself. You can alter your M3, and add your other M commands here.
Some of the mods you make though are a little odd, M and G code does vary slightly between machines M commands being more machine specific, but M3 is near always standard for start spindle.
G1 Z100. > GO Z1 G1 to G0 bit just changes from a feedrate feed to rapid speed move. Z100 is probably to get the tool up to a safe distance above the work before other moves occur. Many people operate their Z axis differently, Z is usually parked up where Z=zero (machine co-ords), then you bring Z down to touch onto the workpiece and reset Z (work coords) to zero. Depending on your machine it may now be able to achieve a Z100 command. Within type 3, this will be controlled in teh machine dimensions, or part of the tool setup, I do recall type3 doing something a little odd here, but don't have a working version at present. But look in those areas for a figure of 100 change it and see what happens.
Your F feed commands are all changed in your tool table, and you can edit them when you edit yours tools.
I hope that helps you get started. I would however try contacting type3 from their web site to see if they will give you any support. It would be nice if they sent someone an instruction set for their post processor that we might all share (one can always hope). If your copy turns out to be fake, they'll just refuse support.
Regs Mark
