586,630 active members*
2,203 visitors online*
Results 1 to 8 of 8
    Dec 2011
    Plasma cable in drag chain?
    Is it a normal practice to put the cord for the plasma in the drag chain with the other wires (for the steppers)? I was woried about possible interferance from the high voltage of the plasma cable....
    --John
    24223
    Many commercial machines follow this practice, including the PC based controllers.
    But it is normal for the machine torch to have a heavy copper braid shield that also carries the high frequency pilot arc conductor, if used.
    Al.
    Albert E.
    Jan 2011
    My plasma torch lead is in the same cable chain as all the rest of my wires, no problem. I have a Hypertherm Powermax 45, which is a non-high-frequency cutter...that probably makes a big difference.
    Carl
    Sep 2010
    X2!
    I'm running the same as I Lean and have never had any trouble with it.
    Powermax 45 as well.
    Dec 2011
    Cool beans guys, what size drag chain did you use on gantry, and what size did you use on the table (I keep getting which is called X and which is called Y mixed up)? Once you let me know ill order mine.
    Jan 2011
    I used Igus 20.2.055, it's about 1" tall by 1 1/2" wide inside dimension. Everything fits fine, but there's not a lot of extra room. (don't get anything smaller, is what I'm saying)
    Carl
    Dec 2011
    You used the 1 1/2 for both the X and Y?
    --John
    Jan 2011
    Yes, same size chain everywhere.
    Carl
  1. Chain drive plasma table
    By MonoNeuron in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 10-10-2014, 01:06 PM
  2. My Dragon Cable Project (E-Chain)
    By msimpson99 in forum DIY CNC Router Table Machines
    Last Post: 09-13-2011, 09:34 PM
  3. cable and chain drives
    By stepperhead in forum DIY CNC Router Table Machines
    Last Post: 04-01-2009, 01:41 PM
  4. cable carrier / chain
    By hpghost in forum Open Source CNC Machine Designs
    Last Post: 05-02-2007, 02:10 PM
