I picked up a 1980 KMB1 with a bad servo board a couple months ago. Instead of repairing it I'm in the process of retrofitting with mach3.
The question I have now is on the VFD. I have attached spec plates for the old VFD and motor.
The old VFD says it is 5HP, the motor plate says that its a 2HP motor. I'm not finding a 5HP VFD that runs from 1PH power. Highest one I have found so far is a 3HP. I'm assuming that I should be fine running the motor with the 3HP unit since the original was a 5HP unit.
Is it worth down grading to a 3HP VFD?
This machine is in a home/hobby shop. Would be nice to have a 5HP spindle but not really sure how that works when the motor is only rated for 2HP.
This is the 3600RPM spindle according to the manual.
