Originally Posted by
ckirchen
While cleaning our GT-20, which has run steady for the past 3 years, one of my operators came across an unconnected (green/yellow) wire on the back of the machine, just above the lube rack.
The ring terminal shows no sign of ever being connected, nor is there an unused stud near it.
By tracing the wire back to its origin, it looks like this is the bonding wire for the turret. Having gone through a CSA special inspection myself (for equipment that we built), I know that the bonding wire is important (i.e. continuity across the linear ways/bearings is not an acceptable method for bonding).
I've talked to the local HFO, but they couldn't find it in their documentation.
Does anyone else have a GT-20 with the turret? Could you check to see where the wire connects to?
Thanks in advance,
Chris
