586,123 active members*
3,277 visitors online*
Results 1 to 12 of 12
    Oct 2007
    37
    Artcam rapids
    Hello, I have a problem with my artcam post and I can't figure out how to change it to do what I want. I want in the begining of the file first rapid speed on X and Y and then with Z.
    This is how it looks now
    N7 G0 X1.79 Y-48.87 Z30.00
    N8 G1 Z15.00 F3000
    and this is how I want it to be
    N7 G0 X1.79 Y-48.87
    N8 G0 Z30.00
    N9 G1 Z15.00 F3000
    I've tried to change in the post this line
    FIRST_RAPID_RATE_MOVE = "[N] G0 [X] [Y] [Z]"
    to this line
    FIRST_RAPID_RATE_MOVE = "[N] G0 [X] [Y]"
    RAPID_RATE_MOVE = "[N] G0 [Z]"
    but it's not working. So please can someone tell me how to do this. Thanks.
    Peter
    Apr 2007
    151
    Why not just edit the code in your controller?, I use Mach3 where you can edit Gcode at your machine.
    Mike
    Oct 2007
    37
    Hi Mike, the reason is that I use a lot of programs and if you use different dia of tools you must recalculate toolpaths. I just don't have time to edit code every time.
    Peter
    If the Z 30.00 is constant, try this:
    FIRST_RAPID_RATE_MOVE = "[N] G0 Z30.00"
    Oct 2007
    37
    Hi ger21, I've tried this and when I open artcam it gives me error message:
    duplicate statement found Line 53 FIRST_RAPID_RATE_MOVE = "[N] G0 Z30.00"
    Peter
    I don't use ArtCAM, so can't be much more help? Can I see the entire post processor?
    I'm assuming you're getting the error when trying to output g-code?
    Oct 2007
    37
    Here is post and manual for editing if it will be in any help.
    Peter
    Attached Files Attached Files
    Dec 2011
    59
    The rapid feed rate output are controlled by
    First_Rapid_Rate_Move & Rapid_Rate_Move which is why your most likely getting a duplicate
    Which post processor are you trying to edit?
    Gary
    Beckwith Decor Products
    ArtCam Reseller/Trainer, Custom tooling & Onsrud Dealer
    Oct 2007
    37
    Quote Originally Posted by Gary-BDP View Post
    Gary
    Mach3 mm post
    Peter
    Dec 2011
    59
    Mach3 mm post
    but which one?
    Which version and build of ArtCam are you using?
    Gary
    Oct 2007
    37
    I use Artcam 8 pro.
    Peter
    Dec 2011
    59
    Send me a small toolpathed .art file of a 2d shape and I will get your post adjusted. You're actually using the mach2 post p
    will be out for a bit but can do it this afternoon
    Gary
  1. ArtCam/ Artcam Express IMPORT (STL file)
    By milepost131 in forum ArtCam Pro
    Last Post: 03-04-2014, 03:13 PM
  2. artcam 2010 examples to artcam 2008
    By mishu28nmv in forum ArtCam Pro
    Last Post: 06-15-2011, 06:27 PM
  3. Controling Rapids
    By Astroguy in forum Rhinocam
    Last Post: 01-26-2011, 05:19 PM
  4. rapids
    By millman52 in forum Mach Software (ArtSoft software)
    Last Post: 11-01-2008, 01:41 AM
  5. Fadal rapids
    By Garypl in forum Fadal
    Last Post: 11-03-2005, 09:36 PM
