586,072 active members*
4,737 visitors online*
    Mar 2005
    816
    Precision Drilling RFQ's wanted
    I am looking for any and all precision drilling RFQ's on small parts that are under 13"x16".
    These are normally any drilled hole that have position and/or runout tolerances under 0.003". I will precision drill any hole(s) you need that are 1/2" and under. I can also apply finish reaming to closer than that. I can also do precision countersinking to 100 degree for aircraft rivets. If you need holes larger than 1/2" (0.500") up to 1", can do that as well.
    I will drill these materials:
    1018, 4340, 4130, 4140 Steel
    2024-T3, 7075-T6, 6061-T6 Aluminums (Kaiser & ALCOA)
    Nylon 6/6 (any type including wear resistant grades)
    Some others... just ask.
    Supply print as DXF and/or DWG. Can convert others. PDF prints are ok too.
    If you supply line drawing or sketch I can also CAD for you.
    Mar 2005
    816
    Re: Precision Drilling RFQ's wanted
    We are still taking drilling jobs. Especially on parts that are smaller than 6" x 12" x 16" (152.4mm x 304.8mm x 406.4mm). No exotics. mostly Aluminum and Steel.
    We prefer parts that are 1018 and 6061..
    Private message me here if you have need for accurately located holes and accurate diameters.
  1. G87 wrap drilling or cross drilling
    By Drake75 in forum G-Code Programing
    Last Post: 05-14-2013, 02:30 PM
  2. Spot Drilling/Center Drilling Steel 55 HRC
    By JWB_Machining in forum MetalWork Discussion
    Last Post: 03-11-2009, 07:35 PM
  3. Precision hole drilling?
    By sp1nm0nkey in forum MetalWork Discussion
    Last Post: 11-20-2007, 07:30 AM
  4. drilling and drilling cycles tutorial
    By wmorre in forum MetalWork Discussion
    Last Post: 10-19-2006, 12:30 AM
  5. Replies: 6
    Last Post: 03-06-2004, 05:11 AM
