586,104 active members*
3,276 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > What it tests the precision cnc milling?
Results 1 to 7 of 7
    Feb 2012
    Smile What it tests the precision cnc milling?
    Hello
    I bought a three-axis milling second hand. (For metal - Moulding)
    What tests will determine the accuracy?
    Public test to determine whether this machine is good or not?
    How are the mechanical tests?
    Thank you
    Apr 2012
    34
    Try milling out a circle.
    Example: Try milling a 50mm circle, check if the circle really is round by measuring across it in both directions x,y. Is it 50,00mm or is it perhaps 50,1? 49,9?
    Mill a straight slot.. Say a 50mm slot and then measure to check the results..
    May 2012
    29
    Another good way is to jog a stepper, from the computer, the entire length of the axis. If its a 48" axis, tell the software to move 48".
    Measure the actual distance traveled and compare it to how much the computer told it to move.
    Nov 2009
    314
    Except the aboving 2 methods, draw a large rectangle or make dots on the four corner of the material ,test the diagonal . When you test the circle as danande said , check the circle is smoothly or not ,that means no waves and jags .
    Feb 2007
    505
    Wink calibration
    Quote Originally Posted by David7 View Post
    Hello
    Thank you
    A search on youtube might help.
    [ame=http://www.youtube.com/watch?v=XkO5tc-jSxw]Improved Mach 3 Axis Calibration - YouTube[/ame]
    Feb 2007
    505
    Wink
    oups posted twice
    Feb 2007
    505
    oups posted twice
  1. Small precision plastic milling
    By piGuy in forum RFQ (Request for Quote)
    Last Post: 09-19-2011, 12:46 AM
