In my free time I have been playing with cad and have come up with a possible design for a benchtop machining centre tough enough to do some proper work.
Specs would be:
16c auto collet spindle
20mm thk linear rail on all axis
16mm ballscrews on all rail
Plate aluminium construction dowelled at all joints - base 12mm - rear backplate 16mm thick tailstock 30mm headstock 40mm
Live Tool ATC
400W mitsubishi Servo spindle
200W mitsubishi servo's on other axis
Running mach 3
I really want to combine the awesome looking machine blight has made and a machine on the mach3 forum:
http://www.machsupport.com/forum/ind...c,11422.0.html
Can anyone see any immediate flaws in the design? Sizes are about 450mm x 700mm x 450mm so its quite small. I already have servo's, ballscrews, drivers, linear rail and some chunks of aluminium so it would make a good summer project.
I would love it to do polygon turning also but so far have not found a solution to where the tool would be mounted. Youtube polygon turning if you have a spare half an hour!
Rob.
