586,096 active members*
3,732 visitors online*
    Feb 2012
    Basic advice needed UK
    Hello
    I have tried reading through some old threads, but much of the content assumes a basic knowledge of CNC / Milling which I dont have.
    I wish to produce 7" high toys. 50 from wood, 50 from coal and fifty from aluminium. For want of a better explanation they are small fixed statues. Mass production / moulding / carving does not suit such small quantities, maybe CNC / milling does ? All toys are identical. I am aware there are various sizes of CNC machine, and perhaps the option exists to 'cut' them all out of one piece of material on a large machine, or individually on a small machine.
    I have absolutely no idea of costs, is there any rule of thumb that can be applied ? I have a full scale maquette of the statue / toy I wish to produce, is this sufficient ?
    Any help at all would be very gratefully received.
    Many thanks
    Pete
    Hi Peter,
    you have pm
    Northmeade CNC : Freelance ArtCam Programming http://www.northmeade.co.uk
  1. Material advice and advice needed
    By kiyoukan in forum Mechanical Calculations/Engineering Design
    Last Post: 02-15-2012, 08:20 PM
  2. Advice needed
    By JimmyPPD in forum Want To Buy...Need help!
    Last Post: 01-15-2012, 12:14 PM
  3. Need advice on basic structure decisions.
    By nokode in forum DIY CNC Router Table Machines
    Last Post: 11-24-2011, 12:18 AM
  4. Bridgeport Basic Q's - quickish help needed!
    By ASTRO_AL in forum Bridgeport / Hardinge Mills
    Last Post: 10-24-2006, 12:45 AM
  5. Basic Sheet Metal Work Needed
    By Mark30504 in forum Employment Opportunity
    Last Post: 10-09-2006, 04:55 AM
