586,032 active members*
2,962 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > AutoCAD 2D Milling CAM Recommendations
    Oct 2011
    12
    CAM Software Recommendations
    CURRENT:
    1) Have a old benchtop mill/engraver that is near dead and never could cleanly import the AutoCAD files in.
    2) Ordered for a Haas MiniMill to replace and expand our capabilites some.
    3) NON-machine house (no CNC operators - our Tech guy and Engrs are support to the assemblers).
    4) Primarily this cell assembles custom light electro-mechanical assemblies where we mill low volume (5-10/day) plastic cases for switches, etc to be mounted into the case.
    5) AutoCAD 2007 files.
    RECOMMENDATIONS:
    - One local knowledgable rep. is advising SurfCAM (he also carries FeatureCAM and DELCAM). My brother's large machining company uses MasterCAM. I have heard some use BobCAM as well.
    We need good same day support and software that works. Thanks!
    Dec 2007
    496
    Take a look at Dolphin cad cam. Seems right down your alley.
    May 2008
    266
    Are you planning on making much/any curvy 3d shaped stuff like vases and computer mice etc? If not then those recommended CAM programs are probably going to be way over the top with a price to match.
    Check out the CamBam forum and some of the work it can produce here: Members Projects
    CamBam does 2d/2.5d better than just about anything else out there and wipes the floor with other 3d software of similar (and greater) price.
    The forum is busy and usually 'manned' 24/7, so help is never far away.
    Martin.
    Jan 2004
    3154
    Sounds like 2D would be more than enough for you.
    Do you use SolidWorks?
    HSMWorks is a free integrated solution that is very high end (they are teasing us into wanting to buy the full HSMWorks pkg)
    www.integratedmechanical.ca
  1. Milling from AutoCAD LT
    By nelrodamus in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-06-2010, 03:17 PM
  2. Recommendations for clean HDPE milling
    By cnczoner in forum Uncategorised MetalWorking Machines
    Last Post: 10-04-2008, 04:00 AM
  3. Milling Brass 360, recommendations?
    By skyline in forum MetalWork Discussion
    Last Post: 06-09-2008, 09:58 PM
  4. Need recommendations for milling titanium
    By jeremyinnys in forum MetalWork Discussion
    Last Post: 09-21-2006, 11:15 AM
  5. Recommendations for milling thick aluminium
    By Rhodan in forum Mechanical Calculations/Engineering Design
    Last Post: 09-04-2006, 02:14 AM
