586,114 active members*
3,204 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Replace the batt on a Haas super mini mill
    Nov 2006
    382
    I am new to Haas. My machine is comming up with a batt error. Is it located like all others, behind the screen on the button panel? Do not turn the machine off to replace it?? Someone please answere today if possible.
    Jetski (alias Tooling and Engineering Czar)
    "I may not have the keys to success.. but I have learned to pick the locks"
    Apr 2004
    45
    The Battery is located on the processor in the back cabinet. You'll have to clip on a good battery while you solder in the replacement. Before you do this back up you params, settings, and programs twice.
    Nov 2006
    382
    Question Please address me as Haas Noob or rookie
    I have worked on Fanuc, and Hurco (I know dirty name in the Haas forum). I am seeing nothing like a batt. on this board (top left corner in the back). Is it square, or round? Is there a way to get a photo or something I am at a loss here. I have replaced batt on the others and you have to do them under power. Sorry for being ignorant on Haas. I am still on baby steps on these. Thank you for the help in advance.
    Oct 2005
    80
    Flash Memory vs Battery
    Does anyone know why Haas isn't using a mimimum amount of non-volatile flash memory instead of a battery to hold parameters, settings, etc?
    Nov 2010
    Hi ! attached prcedure to change battery on Haas .
    Attached Files Attached Files
  1. Engraving on an Arc using Haas Super Mini MIll
    By chop5280 in forum Haas Mills
    Last Post: 02-25-2015, 09:36 PM
  2. variables when probing on haas super mini mill
    By rusty1979 in forum Haas Mills
    Last Post: 11-30-2010, 07:22 PM
  3. Haas Super Mini-Mill and Haas Trunnion Table
    By Gabe Newell in forum Haas Mills
    Last Post: 06-07-2009, 07:23 PM
  4. HELP!! Haas Super Mini Mill
    By CountBraden in forum Haas Mills
    Last Post: 07-07-2008, 12:20 AM
  5. HAAS Super Mini Mill
    By Ford25 in forum Haas Mills
    Last Post: 09-07-2007, 02:01 PM
