586,817 active members*
6,275 visitors online*
Thread: axis fault 7
    Oct 2010
    4
    axis fault 7
    I have a Bridgeport VMC 760/22 dx32 controls, siemens drives. Im getting an axis fault alarm. The X drive module is displaying and error code "7". I have the maintenance manuals, but its not really saying what, where or how to check the things that might be causing this error. There is a flow chart in the manual, but I'm not familiar with the terminology or the symbols.
    Anyone have any ideas on how to do any checks?
    Nov 2004
    3028
    I believe that a alarm 7 indicates a open wire. Since this is the X axis. That would make sense. There are 3 cables going to the motor which moves with the saddle thus flexing in that wireway and prone to hardening from oil and coolant and the cable breaking.
    There is a encoder cable, but my concern is for the armature cable and motor tach cable. There screw into the motor side.
    The X and Y motors and drives are identical. So those can be swapped for diagnostic purposes (one at a time). Mark the optimization cards with a Sharpie as those stay with their intended axis.
    George
    Oct 2008
    44
    Drive is faulty. Took out the axis module and check for opened fuse, caused by shorted IGBT.
  1. C axis fault
    By Konstrukter1 in forum Fadal
    Last Post: 02-09-2020, 10:40 AM
  2. A Axis Fault
    By rrbmachining in forum Haas Mills
    Last Post: 02-07-2012, 09:16 AM
  3. Z axis fault #9
    By dcalp in forum Fadal
    Last Post: 11-28-2011, 04:30 PM
  4. X axis Fault
    By TR MFG in forum Fadal
    Last Post: 12-06-2007, 04:23 PM
  5. C axis fault
    By Rudee in forum Fadal
    Last Post: 05-13-2005, 05:58 PM
