587,070 active members*
3,328 visitors online*
Results 1 to 5 of 5
    Mar 2005
    73
    257 C-AXIS OR LS MALFUNCTION
    I have a Slant Turn 30 ATC with a Mazatrol T3 and I am getting an alarm that I can find no information on.
    257 C-AXIS OR SHIFT LS MALFUNCTION
    when I try to switch to the C Axis. When I switch it on it rotates the chuck, slows and stops then gives the alarm. I can see on the headstock that the proximity switch is activated so apparently it is indexing to the correct position. Any help would be appreciated!
    Thank you.
    "Fire is cool" -Beavis
    Mar 2005
    73
    Bump
    Re: 257 C-AXIS OR LS MALFUNCTION
    Hi!
    I have exactly the same problem, I have a Quick turn 10N ATC with a Mazatrol T3.
    How did you solve it?
    Last month, it make me exactly your trouble, i just open the gearbox, replace the gear and it's working for about a month but now i have the same trouble again.
    Jul 2019
    53
    I think it is the spindle encoder that does not index the c-axis or if the card inside the male spindle works
    This morning it gave me the same problem again. If it was an encoder problem, would it work 2 or 3 days working good and suddenly redo the problem?
    Like last week, I just open the gear box, put back manually the gear at the right place and it work good now, but I know then i didn't solve the cause of this, i just repair the consequence and it's just a question of time and it will make the same problem.
  1. EEROM malfunction
    By Tom Newsome in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-08-2012, 09:16 AM
  2. spindle malfunction
    By kenny wright in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-30-2012, 05:10 AM
  3. Strange EMC malfunction
    By mykrowyre in forum LinuxCNC (formerly EMC2)
    Last Post: 03-13-2011, 11:01 PM
  4. Fadal VMC 40 ATC malfunction
    By mrcslmd in forum Fadal
    Last Post: 09-01-2009, 08:05 PM
  5. G203v Malfunction
    By jhowelb in forum Gecko Drives
    Last Post: 08-09-2007, 11:07 PM
