586,113 active members*
3,268 visitors online*
Results 1 to 19 of 19
    Feb 2010
    230
    Helical flexible couplers
    I have a need for (3) helical flexible couplers with a 1/4" bore on one side
    and a 3/8" bore on the other. When I search Ebay and the web it seems
    all the suppliers are in China. Does anyone know of a USA source for the
    above couplers? Dumpster sells couplers but they are not flexible.
    Regards, Carl
    Jul 2004
    42
    I think i have some in the shop at home. Ill check tonight and get back with you.
    Joe
    24221
    Helical Products have reps across N.A.
    There is also Misumi USA who stock a range.
    I would suggest paying a bit extra and get stainless if this is for stepper/servo application.
    Al.
    Albert E.
    Feb 2010
    230
    Al.
    Could you provide a link where these stainless couplers could be purchased online? Thanks AL!
    Regards, Carl
    Feb 2010
    230
    Quote Originally Posted by wantacnc View Post
    Joe
    I would appreciate that Joe, thanks!
    Regards, Carl
    Apr 2007
    8082
    Al.
    Helical Products couplers
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    24221
    It looks like Electronic Salesmasters cover Ohio.
    Electronic Salesmasters Incorporated
    Al.
    Albert E.
    Feb 2010
    230
    Quote Originally Posted by CarveOne View Post
    Thanks for the info. Helical products has exactly what I am looking for
    but no online sales. There are several distributors here in Ohio that I will
    have to contact once I figure out the right part number. Thanks again!
    Regards, Carl
    Feb 2010
    230
    Al.
    Yes, I looked at the Company given to me by CarveOne and they are a
    local distributor. Thanks for the info. It's amazing how everyone can give
    me info that would take hours to find on the web. Google and other search
    engines seems to be saturated with Chinese companies.
    Thanks for your help!
    Regards, Carl
    McMaster Carr has them.
    Jul 2004
    42
    [ame=http://www.amazon.com/Ruland-PCR16-6-6-SS-Clamping-Coupling-Stainless/dp/B0060LUGUW]Amazon.com: Ruland PCR16-6-6-SS Clamping Beam Coupling, Stainless Steel, Inch, 3/8" Bore A Diameter, 3/8" Bore B Diameter, 1" OD, 1-1/4" Length, 30 lb-in Nominal Torque: Industrial & Scientific[/ame]
    I have 12 of these, PCR16-6-6-SS, They are .375 x .375. I don't know if a split bushing would work to reduce .375 to .250 or a solid sleeve loc-tite to the shaft? Could also machine the sleeve if you think they would work for you.
    Joe
    May 2010
    94
    Helical couplers aren't the best choice for cnc. look into buying something like an oldham coupler.
    McMaster-Carr.
    Buy 2 hubs and one disk, that makes a complete coupler. Higher torsional stiffness = less positional error, at least between the leadscrew and the motor..
    Feb 2010
    230
    Joe[/QUOTE]
    Please see PM
    Regards, Carl
    Feb 2010
    230
    Quote Originally Posted by tkubic View Post
    McMaster-Carr.
    Thanks for the info, does anyone else have an opinion on these types
    of couplings?
    Regards, Carl
    Feb 2010
    230
    Thanks for the info. Do you have an opinion on the Oldham type
    of couplings?
    Regards, Carl
    Never used the Oldham type.
    Feb 2012
    I can't see how Oldham couplings would be better than helical couplings:
    * They have a plastic disk that can wear and introduce backlash, helical couplings have no moving parts to wear.
    * The plastic disk could get coated with wood dust and wear faster. Helical couplings have no wear surfaces.
    * They only compensate for parallel misalignment, helical couplings compensate for parallel, angular, and axial misalignment.
    About the only real advantages I can see to the Oldham couplings is that they cope with larger parallel misalignments than helical couplings and they are usually a bit more compact.
    24221
    One disadvantage to Helical is the 'windup' error, myself, I prefer stainless disc couplings, they are sometimes be a bit larger in dia than the two mentioned, but if there is compact versions available.
    Al.
    Albert E.
    May 2022
    Re: Helical flexible couplers
    Beam or Helical couplings are flexible shaft couplings designed to transmit torque between shafts.www.krogerfeedback.com
  1. Flexible coupler, which one ?
    By finsel in forum Mechanical Calculations/Engineering Design
    Last Post: 07-31-2011, 05:25 PM
  2. Lovejoy Couplers vs. Helical Couplers
    By dpgoldberg in forum DIY CNC Router Table Machines
    Last Post: 09-25-2010, 08:51 PM
  3. Christmas break and 24Hr sale on MPGs and Flexible Couplers
    By phomann in forum News Announcements
    Last Post: 12-23-2008, 03:58 AM
  4. Flexible Motor Couplers
    Last Post: 09-18-2008, 07:01 AM
  5. Helical couplers for $5 !!!!!!
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 03-27-2007, 09:58 PM
