586,103 active members*
3,420 visitors online*
Results 1 to 7 of 7
    Dec 2011
    Unhappy Gecko G540 problems
    Purchased a new Gecko G540 to upgrade from a TB6560 board i have been using but can not get it work . I have wired it up correctly but can not get it to run I have the red led light on but can not get the green led on to run the motors.
    I have a 48 volt power supply connected positive to pin 11 ground to pin 12 and also pin 10 to ground to take it out of estop mode and have the charge pump switch off but still no green led only the red one lights up.
    Please help
    Dec 2007
    362
    Have you followed the troubleshooting procedure in the G540 manual?
    Regards
    Geoff
    Nov 2006
    1036
    Jan 2006
    2985
    Charge Pump Switch?
    Correct Power Supply Voltage?
    Start with no motors connected.
    Matt
    Dec 2011
    Gecko G540 not working
    charge pump switch off wired up to 48 volts pin 10 to ground still nothing not even a red led today ,internal fuse is fine. The red led was just glowing yesterday barely see it.
    Going to wire my TB6560 back up at least it works.
    Dec 2011
    problem solved my stuff up wired wrong miss took pins 1 2 and 3 for 10 11 12 had i back wards . i am the idiot...
    Jun 2011
    LOL :tired:
  1. Ok.... I like the Gecko G540, but...
    By Bob La Londe in forum SmoothStepper Motion Control
    Last Post: 06-01-2011, 11:55 PM
  2. Gecko G540 ??
    By gitarre10000 in forum DIY CNC Router Table Machines
    Last Post: 11-24-2010, 04:55 AM
  3. Gecko G540
    By Deb.bosch in forum Stepper Motors / Drives
    Last Post: 03-20-2010, 02:40 AM
  4. Gecko G540
    By rotger in forum Servo Motors / Drives
    Last Post: 06-02-2009, 06:43 PM
  5. gecko g540
    By Teyber12 in forum Benchtop Machines
    Last Post: 05-31-2009, 08:23 PM
