586,108 active members*
2,986 visitors online*
Results 1 to 5 of 5
    Feb 2007
    25
    Carbide Insert Question
    Hello all,
    I'm not an expert when it comes to the huge variety of carbide inserts that are available, but have had pretty good success with the several types that I've used over the years. I just came into a large quantity of Kennemetal CNMG-323K inserts so thought I'd give them a try. I purchased an MCLNR123B holder (made in the US) which I believe is the correct tool for these inserts. My problem is that I can't seem to get even a reasonably good cut with this setup. Facing or turning - both yield a poor finish. I've tried adjusting the tool height, angle, speeds, feeds, etc. I know my lathe is capable of making good cuts - just not with these inserts. It seems too simple so I must really be doing something wrong.
    Thanks,
    MotoDan
    Jun 2011
    22
    Perhaps the wrong insert for the material?
    Feb 2007
    25
    I'm mostly cutting 6061 aluminum.
    Feb 2007
    25
    Forgot to mention that the insert grade is KC990 which looks to be for cutting carbon and alloy steels as well as ductile irons. Can the grade really make that much difference? If so, then this must be why my aluminum is not machining well.
    Feb 2007
    25
    Just remembered that we also tried cutting some 12L14 leaded steel with less than desirable results.
  1. carbide insert lingo
    By Dancy in forum CNC Tooling
    Last Post: 12-13-2011, 09:40 PM
  2. Replies: 0
    Last Post: 11-30-2011, 06:31 PM
  3. Carbide insert Tooling
    By mae1479 in forum Haas Mills
    Last Post: 09-30-2009, 10:27 PM
  4. Optimal Carbide Insert for Cast Acrylic
    By bdphillips03 in forum Glass, Plastic and Stone
    Last Post: 01-27-2009, 04:57 PM
  5. Carbide insert designations
    By mikehg1 in forum Uncategorised MetalWorking Machines
    Last Post: 06-29-2008, 04:08 PM
