586,104 active members*
3,508 visitors online*
    May 2007
    35
    How mach3 DIR pulse works?
    I am little confused about the DIR pin. How it works?
    It is LOW for forward and HIGH for backward or
    Is it LOW and when it goes HIGH changes direction and then goes in LOW again but the motors stay in the changed direction until new HIGH signal occurs???
    Jan 2010
    2141
    At the moment when a step command is received by the driver, the value of the direction signal is checked by the driver and interpreted. Typically the direction signal should be valid for some short duration ahead of the step signal coming in. Mach keeps the direction signal setting steady until it changes, and keeps it steady at the new value until it changes again.
    The actual value of the signal depends on the setting in Mach3 ports and pins (low active with a red X or a green check mark), but the translation into what direction the motor actually moves in depends on how the motor windings are connected to the driver.
  1. mach3, nothing works
    By cowboy in forum Machines running Mach Software
    Last Post: 02-14-2012, 06:39 PM
  2. Replies: 23
    Last Post: 02-25-2009, 01:24 AM
  3. Mach3 can now do 100Khz pulse rates.
    By ger21 in forum Mach Mill
    Last Post: 07-07-2007, 05:51 PM
  4. how to adjust the pulse frequency on mach3
    By thesaent14 in forum Mach Mill
    Last Post: 03-20-2007, 02:18 AM
  5. MACH3 Maximum Step Pulse rate
    By Ken_Shea in forum Mach Software (ArtSoft software)
    Last Post: 09-21-2005, 02:14 PM
