what are S02 init param err 2225 and 2200 ??
This is a servo alarm error that tells you there's a problem with the
two parameter #'s in the error message
2225 SV025 (Mtype) this deals with the position detector type, and is a four digit hex. y
2200 couldn't find a reference to this one, is this the correct number from the alarm?
Did something change on your machine? Was an encoder replaced?
You might want to check cabling etc. This might mean a service call to
mitsubishi. All mits technoloies are still supported.
I got in touch with a Mitsubishi tech and got my machine up and running. Thanks for the tip. jeffea
