Hello CNC Zone. I teaching myself to generate G-codes from my ProE models, so I may get the parts made by sub-contract CNC shops. I have some tutorials, but feel I need a bit of guidance.
My first problem is: I have made a Manufacturing Assembly and successfully created an Operation and NC Sequence to mill the "bottom" of the workpiece. I then want to turn the job over to mill the "top", using a different cutter.
ProE does not appear to want more than one Operation in the Man. Assy, but it will allow multiple Sequences, but only using the same tool. When I created the second Operation, it substituted this for the first Operation, overwriting that in the Model Tree. The "machine zero" Coordinate System, as you experts know, is defined in the Operation (OP010 is the default name that PTC appears to give it). Oddly enough, both Sequences seemed to work, even though they used different Coord Systems. The problem is, the tool is also defined in the Op, so I'm stuck with one cutting tool.
Do I have to create a new Man Assy every time I want a tool change, or is there a way of putting consecutive Operations in the same Assembly?
Any help would be much appreciated. In return, I am an experienced ProE modeller and will answer any questions you have, about creating your parts, assemblies, drawings, mechanisms etc.:bat:
PS My first attempt at a Username was "scrapmaker", but this was taken!
