586,628 active members*
2,559 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Help with determining alloy
    Aug 2005
    52
    I have a part that I need to duplicate. It looks and feels (density) like stainless.
    It is not magnetic which continued to point to stainless (though I know there are stainless alloys that are attracted to magnets). I've cut/drilled stainless (don't know the alloy) before and dealt with work-hardening. This stuff is not nearly as hard. I was very surprised that I was able to turn it down fairly easily.
    Today I drilled a small hole in it and noticed the shavings from the drill were sticking to the bit. I got a magnet and it was clear that the shavings were now attracted to magnets. I don't know much about metallurgy but I found it really odd that shavings from a non magnetic part would somehow turn magnetic.
    Any ideas what alloy this might be?
    TIA
    Aug 2010
    90
    Quote Originally Posted by turbo2ltr View Post
    It is not magnetic.
    TIA
    Hei'ya turbo2ltr, I'll have a stab at that, sounds like a "Martensitic stainless steel", check out Martensitic grades of stainless steel might help, and friction might induce a static charge that appears magntic-good luck :rainfro::rainfro::rainfro: - kelef
    Jan 2010
    2141
    I haven't tried this, but maybe it would do:
    Spark testing - Wikipedia, the free encyclopedia
  1. Determining Latency...Which #?
    By margni74 in forum LinuxCNC (formerly EMC2)
    Last Post: 11-25-2009, 11:55 PM
  2. Determining the master PCB on 10T
    By guhl in forum Fanuc
    Last Post: 01-23-2008, 08:40 AM
  3. alloy 46
    By lelajoie in forum RFQ Feedback
    Last Post: 08-13-2007, 09:34 PM
  4. Determining aluminum alloy type
    By bdrmachine in forum MetalWork Discussion
    Last Post: 12-13-2006, 03:22 AM
  5. Determining VA load
    By Swede in forum CNC Machine Related Electronics
    Last Post: 04-10-2004, 10:00 PM
