586,113 active members*
3,211 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Override travel to get off limit switch...
    Aug 2010
    69
    How can you override x axis feed to get off x axis limit switch?
    Mar 2011
    463
    That depends on the vintage of the machine and the control, but for most of them with the A2100 (which I think you have) if you hold the green power-on button in it will force the drives to stay up so you can jog off the overtravel.
    Once you are off the overtravel switch, release the button and the machine should stay powered up.
    Aug 2010
    69
    Got it.
  1. Cnc lathe override limit switch problem fanuc t15
    By tomislav_kozul in forum Fanuc
    Last Post: 12-31-2011, 10:59 PM
  2. homing limit switch travel
    By tomcorden in forum Mach Mill
    Last Post: 12-24-2011, 12:46 AM
  3. Delta 20 travel limit override
    By hawthorne in forum Dynapath
    Last Post: 07-19-2011, 03:42 AM
  4. adding rapid override switch to 3T?
    By etpm in forum Fanuc
    Last Post: 03-25-2011, 10:16 PM
  5. limit switch override
    By swarfmacdaddy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-12-2004, 10:47 AM
